Evo IX 2-Step doesnt work
Old Aug 29, 2011 | 02:38 PM
5LEEPERISAH23I's Avatar
well i just picked up a Evo IX. The 2 Step does not work. i cant figure out why it does not work. It is set at 5.5k to 2 step but nothing happens. Anyone know what it could be?
Old Aug 29, 2011 | 02:42 PM
EVOSE06's Avatar
If you are talking about the factory 5,500 RPM limit that Mitsubishi gives the car to protect the drive train from abuse, I'm pretty sure that's easily disabled. So unless you bought the car new, the previous owner probably had it turned off.
Old Aug 29, 2011 | 03:39 PM
VIIIdriver's Avatar
More than likely you need to reflash (tune) your pcm,probably the stationary rev limit it's not set up properly in your rom.Good luck !
how do u turn it back on?
Old Aug 29, 2011 | 03:45 PM
how do u check to see if it is setup tho like where do u go in the ROM
Old Aug 29, 2011 | 04:00 PM
Hendrixmx's Avatar
Its under stationary rev limiter in ecuflash
Old Aug 29, 2011 | 04:16 PM
it is setup.. its not working
Old Aug 29, 2011 | 04:22 PM
ProPilot04's Avatar
Can you elaborate on this please?
Old Aug 29, 2011 | 04:31 PM
06RedRalli's Avatar
Car stopped completely...clutch in....put in first gear...slowly raise the rpms...
Old Aug 29, 2011 | 04:49 PM
on ECU Flash it says 5.5k i flash the car n it doesnt work.. if i can the rev limit that works
Old Aug 29, 2011 | 04:50 PM
yes it is
Old Aug 29, 2011 | 10:00 PM
Evo MR IX Fritz's Avatar
im having a simular problem on my 06 mr. but mine was working and tonight it was not. in for info
Old Aug 30, 2011 | 03:31 AM
justastockevo's Avatar
could it be clutch switches not working properly?
btw, any way to log it via evoscan?
Old Aug 30, 2011 | 06:35 AM
Danner's Avatar
Make sure your ebrake is down. 2 step will not work if the ebrake is up and u are just sitting still in ur driveway.
Old Aug 30, 2011 | 06:11 PM
blackenedwings's Avatar
That is not true. If you have the e-brake on you can actually use it to hold the car perfectly still to ensure 2-step is working correctly. Push the clutch in, put the car into 1st, pull the e-brake up, then ease the rpms up to 5500.
