p0401 code
Old Aug 29, 2011 | 03:40 PM
Mr.Quesada's Avatar
p0401 code
I have a 2006 evo 9, can anybody tell me the location of the EGR valve?
Old Aug 29, 2011 | 03:47 PM
Raistlin's Avatar
Under/behind the throttle body on the back of the engine.
This should help you. Check the vac hose first.
https://www.evolutionm.net/forums/ev...codes-tps.html
Old Aug 29, 2011 | 04:30 PM
Mr.Quesada's Avatar
Thanks, thats was very helpfull.
Old Aug 29, 2011 | 04:34 PM
Raistlin's Avatar
I had a vac hose pop off of mine and it ran like poo until I got it back on. Was a very fast fix.
Hopefully that is all it is for you as well.
It seems a lot of people ziptie the things back on.
Old Aug 29, 2011 | 04:38 PM
Raistlin's Avatar
Here is another link it might help a bit more.
https://www.evolutionm.net/forums/9383462-post87.html
Old Aug 29, 2011 | 11:46 PM
ODUB's Avatar
there you go
Old Aug 30, 2011 | 10:27 AM
YogSaahoth's Avatar
Veteran: Army
Zip-tie every vac line you can get your hands on back there....
Old Aug 30, 2011 | 02:15 PM
RjRacing05's Avatar
hopefully the egr port isn't clogged... seen that cause the code p0401 b4 too
Old Aug 30, 2011 | 04:55 PM
geevolution's Avatar
Sometimes it's the EGR Solenoid that's causing the problem.
Old Sep 4, 2011 | 08:05 PM
Mr.Quesada's Avatar
p0401
Thank you guys for all the great help. I found it and fix it. it was just one of the hoses that it was loose.
Old May 14, 2012 | 05:13 AM
EVOkeeper's Avatar
I had the same code p0401 pop up, verified with evoscan and it said it was insufficient egr flow. A quick check around the vacuum lines and i found the hose for the egr valve hanging loose. im happy again, one more day w/o the SES light!
Old Mar 15, 2013 | 04:45 PM
flashevo12's Avatar
I have the same code...do you have to drive it around to get the light to turn off or should it turn off as soon as you get the vacuum line hooked up
Old Aug 17, 2014 | 01:30 PM
novabluebyyou's Avatar
I am once again reminded of how helpful this forum can be. I recently had the "Service Engine Soon" light come on in my original owner, stock 2003 EVO VIII. I took it to my local Auto Zone to have the code read; P0401 EGR related. I get back home, search P0401 on the evolutionm website, and find the common problem of the vacuum hose to the EGR valve coming off. I go to the car, reach under the throttle body, and sure enough the vacuum hose is off. I put it back on, reset the SES light, and it am good to go. Thanks to all that take the time to share their experiences and knowledge!
SmurfZilla
Aug 16, 2015 03:50 PM
Yme
13
Jul 1, 2014 01:31 AM
hiner005
12
Jun 28, 2014 11:32 AM
Speedlimit
For Sale - Miscellaneous Automotive
Jun 24, 2014 08:22 AM
