Newbie Question: Failed Smog inspection because my CEL light isn't working?
Old Aug 30, 2011 | 06:33 PM
CMoney's Avatar
Hey EvolutionM,
Is the Service engine light and Check engine light the same>? I opened up the cluster and bulbs were all there. I checked the fuse and it wasn't missing anything. What can be this problem? Is the Engine service light suppose to come on with the other light when turning the ignition on 3? Any help would be appreciated.
Old Aug 30, 2011 | 06:50 PM
4RETECH's Avatar
Originally Posted by CMoney
Hey EvolutionM,
Yes, the light is to be on when the bulb check happens as you first turn on the key. see if the bulb is burnt out or if power is getting to it when you first turn on the key.
Old Aug 31, 2011 | 11:53 AM
jaybird09's Avatar
clear the codes right before you go test next time!
Old Aug 31, 2011 | 11:55 AM
Kracka's Avatar
You can't just reset the codes and go in, the ECU needs to cycle a certain number of times before it'll pass OBDII inspection.
Old Nov 17, 2011 | 01:44 PM
analogEvo's Avatar
sorry to bump an old thread but did you ever figure out why it didnt come on?
i swapped the bulbs and it still didnt come on? is there a fuse dedicated to CEL?
Old Nov 18, 2011 | 07:19 AM
SmurfZilla's Avatar
Or you can flag OBDII readiness
Old Nov 18, 2011 | 10:56 AM
CMoney's Avatar
I swapped the bulbs in and it came on. So I assume check fuses. If not try another bulb.
topEND
Feb 27, 2014 12:25 PM
Newuser213
Lancer Engine Tech
Jun 8, 2011 01:33 PM
JDMonster
Dec 28, 2007 04:21 PM
abbo
12
Oct 21, 2007 08:27 PM
ariemcd
Aug 23, 2004 05:19 AM
