Temperature/Boost fluctuations
http://www.srtforums.com/forums/f75/...troller-99455/
im telling you, its like the best 10-15 bucks youll spend.
i was skeptical till i used it, and out of curiosity, i tried it on my 240 and it held 22lbs like a champ with no spike or creep. so far its been on my altima for about 35k miles. 12lbs on a stock block altima engine is pretty insane. i set it up once, tucked it away and forgot about it. its that reliable.
The fluctuations in boost are due to the metal (in the spring) slightly changing its properties with a change in temperature. Using myself as an example, my Hallman is mounted to the radiator, so it comes up to temp very quickly. Too, we really shouldn't see boost until the oil temp is up to spec. By the time this happens, the MBC is warm, as well. As such, I see less than 1psi difference going from 90F to 30F. There's elegance in simplicity.
mine is mounted in the engine bay on the fenderwell. not sure how much warmth its getting from the engine. i know when its set to 22lbs, that spring is pretty damn compressed. you can feel the drag on it as you tighten the bolt.
If you're implying that the only reason the boost changes is because of the metallurgy, then I agree with you, as I stated... but I was merely trying to illustrate that your boost controller will need to adjust itself so that it compensates for the changes in the atmosphere. Which... I just illustrated with a whole bunch of maths.
Because afaik, its working fine. My only reason for suggesting I'd get rid of it was to save some coin.
Kreeker
Sep 13, 2016 11:17 AM
bignasty_yagn
Lancer Aftermarket Forced Induction Tech
13
Feb 4, 2010 11:52 AM
onyx1121
Oct 27, 2009 08:29 AM
