Key Won't Turn
Old Oct 9, 2011 | 09:02 AM
VGX's Avatar
VGX
Question Key Won't Turn
While I was filling up gas, my niece had put a piece of clear tape across the ignition keyhole trying to pull a prank on me. I didn't see it and pay no attention and stuck in the key and drove off. Later at our next stop the key will not turn. I assume a small piece of tape had got into it? I made sure it wasn't wheel lock by turning the steering wheel right and left but still won't budge. After about 10 minutes of fidgeting I finally got the key to turn. My question is should I get the ignition cylinder replaced? cleaned, if so, how?
Noob question. Does the transponder in the key have anything to do with the key not turning?
Thanks in advance.
Old Oct 9, 2011 | 09:21 AM
rhd-jon's Avatar
try cleaning it out before you try anything else. If that does'nt help then try something else.
Old Oct 9, 2011 | 10:23 AM
mirkendargen's Avatar
Transponder will just keep it from starting the car, not physically moving. I think you have tape blocking the tumblers or something
Old Oct 9, 2011 | 10:59 AM
Murf's Avatar
^. That tape is messing up the waifers in the ign. Best way is to remove it and pull tape out.
Old Oct 9, 2011 | 01:27 PM
barneyb's Avatar
Thanks in advance.
To remove the switch the steering wheel comes off followed by the clock spring and some other stuff - I'd avoid this unless nothing else works.
Spray the keyhole with WD-40. This will keep the tape from sticking to anything. Scrub the key in and out. Hopefully, the tape piece will move and allow the key to work normally.
The transponder in the key only keeps the engine from running - it has nothing to do with the operation of the key.
Old Oct 9, 2011 | 01:29 PM
DragonDog's Avatar
Also remember to smack your niece upside of her head!
lemon_head
Nov 24, 2025 10:59 PM
CodyL
Jun 3, 2022 03:59 PM
Evo_Goodness
Aug 3, 2016 04:20 PM
live2teach
Jul 15, 2014 05:22 PM
MurderedOut09
Jan 23, 2014 12:35 PM
