advanced keys push button start
Old Oct 12, 2011 | 06:00 PM
sessanator18's Avatar
Their was a thread in the how to forums about installation of a push button start of off ebay i thought the idea was cool but wanted a more oem feel no keys needed. I started to test it out tonight and need help finding a few wires.
1.negative starter output
2.brake input signaling wire
thanks for the help in advance
Old Oct 13, 2011 | 12:33 PM
taylorgang's Avatar
please post an update if you can get the Advanced Key system to work I've been wanting to do it for a while...
Old Oct 13, 2011 | 02:24 PM
1UpMoto's Avatar
this thread might help
https://www.evolutionm.net/forums/ev...tall-ct9a.html
Old Oct 13, 2011 | 03:59 PM
i already used that thread but it doesnt have those two wires listed
Old Oct 14, 2011 | 09:57 AM
ttt today install day need some info the brake i sort of know just want to double check that it goes from the brake switch into the main harness and which of the two wires is the signal one the other is the feed . the push button use the brake as a way of comunicating with the the program fir programming so you dont have the push button held down when the engine cranks it uses a tach wire to figure out your engines rpms
that other signaling wire is a 500ma signal wire i really need help with that one
xjy19860421
Jun 18, 2016 11:09 PM
Skott2k
15
Mar 26, 2009 09:55 PM
frhstrack11
19
Feb 14, 2008 07:51 PM
BadBoyBeltran
Mar 25, 2004 11:15 AM
Iamkar33m
Feb 1, 2004 12:47 PM
