Major Help Needed!?
Old Nov 6, 2011 | 03:54 PM
The 530 Postman's Avatar
Question Major Help Needed!?
Hello I have a serious dilemma on my hands and have no clue whats going on with the evo. Ok so I commute my evo to work 6 days a week 45 miles a day roundtrip so every mourning when I leave after car has warmed up of course I begin my drive and when I start accelerating my turbo timer starts adding seconds well by the time I get to work the turbo timer is at 7-8 min durring the drive the timer never goes down only counts up and it does this at night as well but whats wierd is when the outside temp is over 75 degress I can drive my car as hard as I can and the turbo timer never moves off 0.00 seconds. So only when the temp outside is below 70 degrees the turbo timer acts up my temp gauge on the cluster never budges over half way.Any info would help I drive a 04 evo 8 with 77k only mod it has is a works catback exhaust. And the turbo timer is a greddy. Thanks for your time.
Old Nov 6, 2011 | 03:57 PM
eve-slow's Avatar
Well I doubt that is "Major" but what setting do you have it on?
Old Nov 6, 2011 | 08:08 PM
Set it on auto
Old Nov 6, 2011 | 08:09 PM
Trying to figure out if there is something wrong with the turbo or motor itself
Old Nov 6, 2011 | 09:56 PM
chaosfiend21's Avatar
mine i have to set up myself when im about to shut off the engine. you have an egt gauge?
Old Nov 8, 2011 | 09:06 PM
no egt gauge,,,,And its always under load when the timer starts counting
Old Nov 8, 2011 | 09:22 PM
Lancerboy89's Avatar
http://www.hksusa.com/faq/?ID=1647 hope this hepls but find your timer and make sure u hooked it up right. not try to say u didnt but always good to double check
Old Nov 8, 2011 | 09:25 PM
sujinX's Avatar
i kinda had the same ordeal when i had the tt on my other boosted car. if u idle and drive slow it'll go down. i know this because i tested it. highway driving it goes up and peaks out but when u just sit there and idle in stop and go traffic it counts down. as for the temp, not sure on that. maybe its wired differently than mine?
Old Nov 9, 2011 | 10:21 AM
bnr34rb26dett's Avatar
i started having the same problem a few months back so i just set the timer to 1 min.
it was working fine before. im not sure about 75 deg problem but i think its the wiring. it must have come undone or something
but subscribed
Old Nov 10, 2011 | 05:37 AM
i went in last night to check all wiring. everything looks good. but its still doing the same thing. could this be due to the tune or something software related?
dwn4cause
Aug 16, 2009 09:21 AM
boostedteg99
Jul 10, 2009 12:58 AM
jojipoji
Apr 19, 2008 06:10 AM
k2boarder3187
Dec 28, 2007 04:20 PM
vr4_211
Dec 4, 2005 09:22 PM
