Steering wheel vibration
Old Jan 13, 2004 | 07:19 AM
KazzEvo8's Avatar
Check inflation pressures.
Have wheels balanced by a competent shop.
Have tires checked for improper wear. If wear is a problem rotate more often and get a 4-wheel alignment, you'll not get rid of some ride anomalies until improperly worn rubber is replaced.
The last thing to check would be brakes.
Wheel turn @ braking often indicates a balance/inflation issue. our soft tires need frequent rotation. Odd wear on those tires will cause plenty of vibration - even hop. Rotating those tires to the rear just moves the problem but does remove the vibration in the wheel. That could be a quick check - rotate and see if the problem goes away... unless, of course, the rears are a mess too!
Good luck!
Old Jan 13, 2004 | 07:22 AM
Gracing2000's Avatar
Thanks Bro!!
Old Jan 13, 2004 | 07:25 AM
Hey Guys,
Everyone who has this steering wheel vibration should complain to the manufacturer!! I called last week to complain!!
Here is the # if has the same problem (888) 648-7820!!
Old Jan 13, 2004 | 10:57 AM
Cajun Power's Avatar
2 evo with the same trouble in Louisiana
We have 2 EVOs here with the same problem. At 120mph and + you get a front end chatter. Under breaking there is a choppy break feel and steering vibration 3 out of 5 times when breaking from higher speeds 50 mph+. I threw a weight on a BOH run the other night, This is probably a result of the chatter. I will be retating and balancing thsi week.
Cajun Power (and Volunteer)
Old Jan 13, 2004 | 12:20 PM
NOVA EVO's Avatar
Originally posted by IgotaWhiteOne
u prob warped the rotors that what i would suggest
Yup...probably the rotors...that's the most common cause of vibration...
NJ_evoIXgsr
18
Mar 16, 2017 09:03 PM
slicksta69
15
Jun 20, 2016 09:23 AM
moey124
Sep 28, 2015 07:24 AM
jonsevo
Oct 8, 2007 08:18 PM
atombomb33
11
Sep 13, 2007 01:02 PM
