How much for a 60k tune up for Evo IX usually cost? PLEASE HELP! =(
Question is, what is really what I should change, because some folks said waterpump is necessary and some said it doesn't, some even said spark plugs aren't necessary either, but normally spark plug is necessary for even family cars, so I really need a legit list of what is critical to change. I can't find a list... =(
The shops out there that are charging the amount you listed need to support the facility,employees,etc. also it comes with a warranty.
Of course you could always shop around.
If you are going cheap and the waterpumps not leaking YET.
Just do the fluids(TC,trans,coolant,rear diff),spark plugs,inspect the wires as they tend to arch at 60K(black marks on the spark plugs).do the serp,balance and timing belts. Pulleys are up to you, but I would change them since you are there.
I like these threads because people tend to freak out about how much maintenence cost. But if taken cared of every 60K, it will last you for years.
For me 60K is like every year, LOL
First off?? How long are you going to keep your car??
are you serious? every year? what's the mileage of your car now??
Depends on how the pump looks. Some people dont change it till 120K.
On my car, it's usually 14-16 months or somewhere around that.
Mileage is in my sig. I drive about 120-150 miles a day so I keep up with my maintenance.
If you are on a budget then why not try it yourself? Wish I was closer...I'd stop by to help you out. I just picked up my timing belt kit today at the dealer and payed $285. Contact some of the vendors around here and get the fluids shipped to you. I personally use Pennzoil Synchromesh and pay a whole $7.00 a bottle (3 of them are need for the transmission). Spark plugs you can order at your local auto parts store and pick them up for roughly $3.00 each.
This is probably correct but by 60K the coolant should be changed and if you are aready in for the timing belt replacing the waterpump is pretty easy.
As for the plugs I replaced mine at 60K as well and they looked very good. Still had their gap and minimal wear on the cathode. But I did the whole maintenance anyway since I saved money doing it myself.
why don't you buy a prius so you can save alot of money?? what do you do to drive that much daily anyway?Yea. I'm thinking to do everything, except I'm still confused if I should do the waterpump and will it cost more to do it later or should I do it while I'm there, unless like others that can make it to 120k, I'll think about changing it. also, is coolant hoses included in the first 60k service? cuz the coolant hoses just blown around 70k on my friend's STi, so I don't know if our car's maintenance is same cuz they're similar cars, but STi doesn't require changing timing belt until 90k, so I guess i don't have to worry about the coolant hose yet? it still feels solid.
some evo owners are crazy to say that maintenance is expensive. the same guys put in thousands for mods and upgrades, but when it comes to maintenance their cutting every corner. i'm at 44k and have been doing maintenance consistently. i'll most likely do all fluids (trans, coolant, tc, etc.) next week. i just did brakes (pads, rotors, fluid) a few months ago. by the time 60k rolls around, it won't be a burden on my wallet. and this is common for most cars, maybe in the evo its a little premature than an econobox, but you knew that coming into this world.
Attachment 179527
Here is a pic of one of my spark plugs at 60K. The gap was still good and it didn't have a lot of wear on the electrodes. Like some have said most could go to 100K probably. Also depends on your tune and other factors of course.
1400-1700 sounds right. Its correct. It takes a lot of hours to get this done. Gota drop the oil pan, take apart the pumps, valve cover to replace the valve gaskets, change all the seals etc etc. Basically surgery on your motor without taking apart the cams and rods.
But once done, you wont look back and be paranoid. Just save up. Get it done right.
