What is this?
Old Nov 16, 2011 | 02:53 PM
Piro Fyre's Avatar
What is this?
Bought a shift boot from a member recently so I went to install it. After finding out I already have solid base bushings, I also found this little thing that's zip tied to the shifter cage. Anyone have any ideas?
Old Nov 16, 2011 | 03:04 PM
silver9mr's Avatar
whats done to the car?
Old Nov 16, 2011 | 03:06 PM
Kasaper's Avatar
Speed tap for something that needs 12V. What's it wired to?
mrboost05's Avatar
looks like a left over harness from a turbo timer any wires running back towards the ebrake ?
Vivid Racing's Avatar
Does your car have an aftermarket alarm? It looks like it might be a tilt sensor for an alarm. Follow the wires until they either get to a component or tap into other wires. That mess is definitely not factory.
EDIT: After looking at it some more, it looks like it may be a resistor. Like I said, follow the wires and post up what you find out. I don't think the guys above are seeing the beige block that's zip-tied to the shifter assembly.
Old Nov 16, 2011 | 03:20 PM
mrboost05's Avatar
you would be correct i did not see that beige block on first inspection does not look like any tilt sensor ive ever seen so i think you are on track with the resistor relay or whatever it is.
Old Nov 16, 2011 | 03:48 PM
sinople1's Avatar
Could it be a 02 sensor defouler? I thought ive seen a write up were you wire in this defouler for the secondary 02 by the shifter box
Old Nov 16, 2011 | 04:28 PM
Piro Fyre's Avatar
There is evidence that the car previously had an alarm system since the blinking LED is still there and not even hooked up to anything. I don't think this thing is related to the alarm since this block is hooked straight into the harness itself. I can only guess O2 simulator just like you said but even then, SES light comes on with the O2 heater malfunction code popping up every time so I guess it either doesn't work or it's hooked up all wrong.
I'll try to get more pictures up on where it hooks up to in a bit. Just need to eat some dinner.
Old Nov 17, 2011 | 01:18 PM
Yeah, it doesn't look like any alarm sensor I've seen, but I've only installed Directed products (makers of Viper, Python, Hornet, and others) so I figured it might be a cheap alarm.
Those defoulers are just resistors. I think we're onto something here.
Just follow the wires into the harness and see what they're tapped into. Once you have those wire colors, pull up a wiring diagram for your car and see what those wires are for.
I'm leaning towards resistor to fool the secondary O2.
Old Nov 17, 2011 | 06:40 PM
Piro Fyre's Avatar
Well, it is a resistor for the O2 except the wiring is just a hack job. I can do a better job with just a nail clipper and tape. :/
Whatever, took the entire resistor off the car completely, taped the exposed wires up and just need to get 2-3in of cable to reconnect the white wire that was cut while the previous owner tried to just strip it.
Old Nov 22, 2011 | 02:18 PM
Wow, that's pretty awful. Good thing you found that before something shorted out. Imagine chasing that short down!
Old Nov 23, 2011 | 12:46 PM
3wd's Avatar
3wd
Yicks..Whatever it is, the installer did a hack job on the install.....
AUSyTyIN
For Sale - Cars For Sale
10
Feb 24, 2012 12:53 PM
talentsearch301
Jun 22, 2010 02:23 PM
16ggst
For Sale - Wheels / Tires
23
Apr 12, 2010 11:27 AM
downforceinc
EvoX 'For Sale' Exterior Styling
Jan 12, 2009 02:18 PM
DaMeat
Sep 29, 2008 10:55 AM
