ACD not working; affecting 1/4 time?
Old Nov 17, 2011 | 08:31 AM
cool_as_crap's Avatar
The ACD on my evo isn't working (I think the pump is bad) and I get the three lights on my dash after a minute of driving.
I recently started going to the local 1/4 mile track, but I can't seem to get lower than a 14.1. I'm sure I'm not the greatest driver, but that seems a little too slow.
My question is, when the ACD isn't working, would the open mode affect my quarter time?
Edit:
Evo VIII, mostly stock except for 3" TBE.
Old Nov 17, 2011 | 08:39 AM
b16a2delsol's Avatar
I believe its still a 50/50 lock. It doesn't enter an open state when the pump fails.
What are your mods?
Old Nov 17, 2011 | 09:51 AM
MechTech's Avatar
Im not sure how the diff would behave with the 3 lights. Are you hitting solid boost? Wheel spin? Does the car feel like its pulling normally?
Old Nov 17, 2011 | 09:57 AM
CAD EVO's Avatar
Edit:
Are you tuned for the TBE? If not, your car could be misfiring like crazy and giving you the aforementioned time.
Old Nov 17, 2011 | 11:16 AM
596736's Avatar
There are some very extensive threads on acd pump failures and in this one in particular someone mentions their 60' being drastically affected by a failed acd pump:
https://www.evolutionm.net/forums/ev...l-pay-you.html
Here is the exact post:
https://www.evolutionm.net/forums/9560396-post175.html
Old Nov 17, 2011 | 11:31 AM
Feels normal, but I've only had the car since June, it came with a bad acd.
Not tuned, I didn't think about tuning before doing more mods....
Old Nov 17, 2011 | 11:54 AM
turbotalawd's Avatar
I dont see how a failed pump will affect 1/4 times. It reverts to its standard setting of tarmac as a fail safe. It does not make the car front wheel drive. If you just have a exhaust installed and no tune and you say you are not the best driver, then those times are pretty normal i think. Spend some more time driving the car and get more mods and that time should improve. Also I would suggest fixing the problem anyway.
Old Nov 17, 2011 | 01:09 PM
Lol you will not misfire because of an exhaust.... just a heads up..
Old Nov 17, 2011 | 02:58 PM
CAD EVO's Avatar
So you are saying running a TBE untuned will not create knock/misfire which would then pull timing?
Old Nov 17, 2011 | 10:50 PM
Its not going to "misfire" no. The extra load/boost created with an exhaust will not knock enough for concern. Even when I turned cars up to 23-24psi on stock tunes (full 3 inch on mine and an 05, third I wasn't tuning just seeing what was up with his car) have I ever encountered serious or even above average knock. The timing goes more negative on the rom yes but doesn't result in a misfire.
No need to battle, its just not going to "misfire" or blow your motor from having an exhaust is all I'm saying :-)
Old Nov 18, 2011 | 06:13 AM
GTijoejoe's Avatar
I agree, 50/50 is the normal steady state of the drivetrain... the pump allows the clutches to reduce the torque to the rear, very similar to Acura SH-awd system which reduces torque to one side, inadvertantly transferring torque to the other side.
The systems are made like this because its too much to depend on a pump to give pressure 100% of the time for traction, it would never happen and the warranty would be rediculous.
suprPHREAK
Toronto Lancer Club
62
Dec 15, 2016 10:17 AM
moparfan
Apr 21, 2016 12:49 PM
xReVoKeDz--
Mar 30, 2016 06:38 PM
Evo Man Hunter
Dec 11, 2015 07:16 AM
J!n K@z@mA
Jun 12, 2014 08:31 AM
