Key help and lugnut lock question
Old Nov 18, 2011 | 04:22 PM
Honni414's Avatar
So my evo was stolen and long story short i got it back, but when it was recovered i found some sort of aftermarket mitsu key in it.
When i tried to start it I used both OEM keys and neither would work and some little green key light showed up in my instrument cluster, so i gave the aftermarket key a try and it started up.
How do i go about resetting my keys to be the ones that start the car? im EXTREMELY uncomfortable knowing there is possibly another key floating around for my car (they usually come in twos, right?) and now my key fobs don't even work.
im sure somebody knows how to do this.
also, the car was found with the spare on it and my locking lug nut key is gone too and my local dealership wants $54 just to remove the lug nut locks, i find that crazy as i know that takes 3 minutes to do tops when you have the key for it.
any suggestions on what do do there without paying a ridiculous amount for the short time of labor? i have OEM VIII rims on if there are any questions.
i hope someone can help me, it feels great to have my baby back but horrible to have to deal with all this bullshiet
Old Nov 18, 2011 | 05:15 PM
HN7's Avatar
HN7
That's sucks, sorry to hear that. At least you got it back in one piece and it's running.
About the key, you'll need to take it back to the dealer and let them reprogram the immobilizer. I'd ask them to check the ECU too to see if it's the original one. I heard that car thief can switch your ECU to a modded one then use the aftermarket key to start your car (which would explain your aftermarket key).
About the lugs, no idea but the point of the lock is you can't get it off without the key so... take it to another shop and see what they say.
Old Nov 18, 2011 | 05:27 PM
DJAfterShok's Avatar
Does the keys match to yours? (the part that's cut) It sounds like the thief might of re programed your immobilizer for it to work with his key. Maybe talk to your insurance to see if they will cover the cost to have yours key reprogrammed by the dealer. They would probably want an arm and a leg for it. Where in Wisconsin are you located? I swear its probably the same idiots that are running around Chicago stealing Evo's
Old Nov 18, 2011 | 05:33 PM
sho669's Avatar
I'd also guess the ECU has been swapped, unless they went into your ECU with EcuFlash which is unlikely.
Your SOL on the locks really. The dealer could match the key using their master set, or you can just go to a local tire shop and pay them to remove the old ones and install a new set.
If you can find a cheap set of 4 12pt sockets (3/4" i think) you can pound them onto the locks then remove the lugs, backwoods but I've done it before. Tire shop will use an easy out style socket to remove them.
Old Nov 18, 2011 | 06:47 PM
svt_lightning01's Avatar
Sears sells a tool that I got some lock nuts off with. It's a socket with reverse threaded serrated spiral grooves comes in like a pack of four. Beat on with hammer and break it loose
Old Nov 19, 2011 | 12:39 AM
jonzie04's Avatar
Dont know about the key. But beat a 12 point socket on the lug nut. Glad you got your car back though!
Old Nov 19, 2011 | 10:59 AM
Honni414's Avatar
yes, its cut the exact same way.... so would there be a way to reprogram my immobilizer back to my stock keys without paying an arm and a leg from the stealership?
and im on the southside of milwaukee so thats possible about the chicago idiots but the vehicle was recovered in Madison, WI.
Old Nov 19, 2011 | 01:11 PM
fingjosh's Avatar
damn, idk about resetting the keys... is the cut the same?
Old Nov 21, 2011 | 09:20 AM
Honni414's Avatar
nobody knows anything about reprograming my immobilizer?
Old Nov 21, 2011 | 09:39 AM
sho669's Avatar
If you want to get the car running again you can disable it in EcuFlash, unless you know the code the car had before the dealer is most likely the route you're going to have to take.
Old Nov 23, 2011 | 06:45 PM
Honni414's Avatar
yeah i got the car running, when they recovered it one of the keys they were using was in it. and is the code on that little silver piece that was on the keys that i got with the car when i bought it from the dealership, i know it was a bunch of numbers
Old Nov 28, 2011 | 05:05 PM
EVOVIIImadrid's Avatar
I had the same issue with the lug nuts. Bought a cheap mustang and the owner didn't have the lug key.
Get a socket that is slightly to small for the lugs hammer it on. I got 1 off all four wheels in about 10 minutes.
Old Nov 28, 2011 | 05:36 PM
sKeMoNe's Avatar
Yup what he said ^^
Old Nov 28, 2011 | 07:46 PM
usnevo8's Avatar
I have this same problem, going to go ask some shops tomorrow, and if the prices arent that great then Ill end up trying the larger nut.
Old Nov 29, 2011 | 10:12 AM
It's too easy to do it yourself. Shops charge a lot. Especially if you have more then one lock. Just be carefull not to nice your rim.
panamah_r3d
Aug 15, 2015 06:34 PM
damoevo8
Australian Forum
Jan 10, 2013 04:22 PM
rgonyer
Apr 17, 2010 09:38 AM
beetle_orange
Jul 17, 2008 04:49 AM
autodoodad.com
Evo 'For Sale' Electronics / Lighting / Audio
Jun 4, 2006 09:13 PM
