Sea Foam
Old Sep 12, 2012 | 03:16 PM
  #241
Raptord's Avatar
Originally Posted by Sil'vr-Boi6
Anybody here you Amsoil with seafoam, and ill effects? Has Amsoil said to avoid using this stuff?
Used it (not in the oil though) and didn't have any problems afterwards.
Old Sep 13, 2012 | 06:32 AM
  #242
Sil'vr-Boi6's Avatar
Same here I didn't use it in my oil.
Originally Posted by cursedsm
Cause it has nothing to do with their oil thats why. They think being there oil is this and that the detergents wont help or some odd reason. I just love how companys don't want you to use a product like that but yet, there is no evidence of failures due to it. Seafoam is the **** when it comes to everything. Unless your car has 10000000000000 miles on it and never had an oil change its kinda useless to put in the oil. Being we ( or most of us) take care of our oil changes and what nots its kinda useless to put in the oil. But works really well for most of us who infact do use pump gas. Being I personally run both pump and e85 there isn't as much need for seafoam, but I use it religiously in all my other cars that do not run e85.
I'm a believer in this stuff. I tried it last night after reading this entire thread and follow the intructions(*easiest DIY ever the hose is literally right there.) My VIII didn't smoke excessively, but did for about 30-45 seconds. I pour it both in the tank and let it sip via ntake. This morning once car was cranked, it erupted like I took of the negative battery terminal. It settled to a smooth idle quickly. I really wish this was an exaggeration but this is not. After pulling from the drive I did see a little some for 8-10 seconds than it stopped. throttle is a bit sharper. Stop and Go traffic is smooth from transition from idle to throttle is great in my car, maybe not same result for others.
Old Jan 10, 2013 | 10:24 AM
  #243
silverevo05's Avatar
Bump for this stuff... Just bought some
Old Jan 10, 2013 | 10:49 AM
  #244
ILuvJDM's Avatar
I did my girlfriends car and it runs noticeably smoother. I can't comment on the gas mileage though, I have no idea. She said it was like night and day. Her car has like 120k miles. I've done it on every car I've owned and also my parents... I'm sold on it. I have never put it in the oil though
Old Jan 11, 2013 | 05:54 AM
  #245
boostedmkiii's Avatar
I have been using SeaFoam for a long time, and have always had great results. However, I got tired of paying $8-$10 per bottle, mostly because of how many vehicles I have... 5 cars x 2 bottles per car every couple months (one in the tank and one via vacuum). So I did look up the MSDS, and with some trial and error (along with help from some buddies at Dow Chemical) found a pretty close formula. I have been using this home brew for months now, and it seems to work EXACTLY as SeaFoam does.
Plus it costs me about $6 to make 2 gallons
Old Jan 11, 2013 | 06:18 AM
  #246
ILuvJDM's Avatar
you shouldn't need to seafoam your car every couple of months... they actually advise against excessive use. Use it once only if you bought the vehicle used, otherwise take care of your vehicle and it should stay fresh
Old Jan 12, 2013 | 05:10 PM
  #247
Somthy's Avatar
I may need to try this stuff out.
Old Jan 12, 2013 | 09:29 PM
  #248
Fireescape's Avatar
Could you post up the ingredients you used, only one place I've found in Australia to buy it (on ebay) and they want $34 a can posted, be really good to brew some up myself. I would buy some from the states but no one will post it because it's flammable. Any help will be very much appreciate.
Old Jan 13, 2013 | 12:12 PM
  #249
steven121's Avatar
How would you use this for an oil change? Do you drain the oil and idle it for a few seconds, add it to the oil then idle it. Interested i want to change the oil soon
Old Jan 13, 2013 | 02:45 PM
  #250
slimjim1804's Avatar
Wow. I always thought Seafoam was another auto parts gimmick item, like radiator stop leak and head gasket sealant. This thread has certainly changed my opinion. I'll be adding this to my to do list for the Evo and the rest of the stable.
Posted from Evolutionm.net App for Android
Old Jan 14, 2013 | 08:49 PM
  #251
Robdeep3's Avatar
have used seafoam on several of my cars and always gain a bit of mpg's after using it as well as smoother idling on some of the cars.
Old Jan 17, 2013 | 06:24 AM
  #252
Let me clarify- by every couple months, I specifically meant 4-5 months. Which is pretty close to SeaFoams recommended instructions, depending on how many miles you put on a vehicle. I do a lot of driving, so this ends up being routine with every oil change.
Also, I did some testing on an old beater to see what negative affects would happen with over use... I used one can via gas (only 3 gallons max) and one can via intake/vacuum every week for 4 weeks. Only negative that I foun was plug fouling: a moderate amount. Therefore, I feel my schedule is perfectly reasonable... To each their own, however.
First I need to correct my typo... I meant to say that my formula makes about 1 gallon for around $6.00, not 2 gallons.
Please excuse U.S. measurements:
Lubricant: 1/2 gallon of diesel fuel: $1.40
Cleaning agent: 1 quart naphtha (I use charcoal lighter fluid due to higher viscosity): $2.00
Water removing agent: 1 pint isopropyl alcohol (as pure as possible. I use IsoHeet): $2.00
To get a more exact replica, you would have to mix these parts at a certain tempurature in order to get the right viscosity. However, after many failed attempts, I just have up on this as I found no real difference in performance.
I hope this helps!
Old Jan 17, 2013 | 08:37 AM
  #253
ILuvJDM's Avatar
ah, I was envisioning every 1-2 months
Old Jan 17, 2013 | 01:54 PM
  #254
Fireescape's Avatar
I hope this helps!
Thanks mate, it does. time for some shopping.
Old Jan 17, 2013 | 05:49 PM
  #255
Hitmachine101's Avatar
great stuff
vac lines is a def plus
in the gas tank its great stuff
you have to be careful adding it to the crank case, it will dilute the oil if you add to much thus putting excess wear on all your bearings and lets face it NOT A GOOD IDEA ON OUR MOTORS
not a good idea period
so if your a fan of putting it in the crank case to loosen up some sludge and clean the motor -- i am for sure once in a while
put 1/2 to 1/3 the can in the crank case 20-30 miles before you change the oil, run it ( for me thats to and from work ) then change the oil
ive had great results on all my other cars better gas mileage from hondas to bmws, less oil consumption on oil burning motors and better ( butt dyno ) feeling on the hsp and throttle response end of things
