Sea Foam
Old Jan 7, 2012 | 11:23 PM
  #211
CurseDSM's Avatar
Originally Posted by kyoo
i thought there's a chance of hydrolocking the engine?
If you put to much in the brake booster then yes you can hydrolock it. Don't ask me how I know that because it sucks trying to dryout the motor in a v8. If you poor a third of it in and keep the car idled, it shoudl be fine. Yes you do burn it off, as someone stated but thats fine. Once it is gone it will still be in the system and it will clean out the car. If you put to much in at one time and the car stalls, and you try to restart it, then yes you have to be careful of hydrolock. Using a third of it shouldn't hydrolock the car but it has to remain running. If it dies out restart the car then add continue to add. DO NOT LET THE CAR STALL AND ADD IT TO THE LINE IT WILL IN FACT HYDROLOCK.
Old Jan 8, 2012 | 08:34 AM
  #212
kyoo's Avatar
gotcha - that's what i was worried about yea. I did pour it in though, and did get quite the smokeshow. must have just done it too slowly before out of fear of hydrolock. everything worked fine though. i think someone before said just in case you can give the car some gas so it idles higher/won't stall (friend or pulling the cable)
Old Jan 8, 2012 | 08:45 AM
  #213
CurseDSM's Avatar
What I usually do is get a 1/4 inch hose off the intake mani put it in the can while it is idleing and let it take it that way but again becareful not to stall the car. Or if you have a buddy or someone there just have them hold it at like 3 grand and just drop it in the bottle a little at a time till its gone.
Old Jan 8, 2012 | 06:35 PM
  #214
Ramen_Noodle's Avatar
This is exactly why I like using the aerosol form of Sea Foam for the Brake Booster. A lot more control with how much get's into the motor, seems to work just as well as the liquid, and it's really less hassle IMO.
Old Jan 8, 2012 | 07:07 PM
  #215
CurseDSM's Avatar
Yeah I just learned about the aerosol stuff but unfortunately they don't sell it anywhere in town here. I will have to take a drive and see if I can find some for next time.
Old Jan 19, 2012 | 09:53 PM
  #216
wordapp!'s Avatar
I used a can a couple of weeks ago, and I get atleast 50 more miles to a tank....
Old Jan 20, 2012 | 02:29 PM
  #217
ABNEVO's Avatar
What mod do you have if you don't mind I ask. Thanks
Old Feb 2, 2012 | 04:16 PM
  #218
Jtoys's Avatar
Not reading through. But doesn't it say not to use on turbo cars right on the can?
Old Feb 2, 2012 | 04:29 PM
  #219
CurseDSM's Avatar
nope
Old Feb 3, 2012 | 07:10 PM
  #220
ABNEVO's Avatar
HKS cam 272, enjin intake and piping, 3" TBE/down pipe and test pipe, MBC, and Fuel pump. The car is making 330whp. I normal get about 210 or 220 miles per tank but now I get about 250-260 so it's within the 50 miles gain.
Old Feb 5, 2012 | 01:30 PM
  #221
bboypuertoroc's Avatar
Veteran: Army
So I just put a can in my gas tank when I filled up today. After less than a MILE of driving I noticed a difference. It's simply amazing. The on/off throttle bucking issues I've been having is completely gone and my idle is smoothing out significantly. I only have about 15 miles driven so far on this tank with the seafoam in it and I'm just blown away. Next oil change I'll be dumping another can in the tank along with half a can in the oil and the other half in the vacuum lines.
WINNING
Old Feb 5, 2012 | 02:11 PM
  #222
Jtoys's Avatar
I have never used this in any of my own cars. I might have to give this a shot. Seems a bunch of people have been having goodluck
Old Feb 5, 2012 | 09:09 PM
  #223
cmspaz's Avatar
WINNING
You'll want to hold off on putting it in the oil until 200 miles before your next oil change. Straight from a Seafoam rep's mouth, that.
Old Feb 5, 2012 | 10:56 PM
  #224
greencow's Avatar
Just ran half a can or so thru mine. Tons of smoke after I let it sit and do it's work. Pulled a plug after I ran it hard, plug looked great, piston looked even better. I'm gonna change my oil next weekend, hopefully can get some better mileage out of her. I used to run a can thru my trans am every other oil change, and it kept it smooth.
Old Feb 7, 2012 | 11:34 AM
  #225
evil.evo's Avatar
Veteran: Army
FCOTM Winner
for those of you that put it in your oil--how many miles are you guys driving before changing your oil?
