Sea Foam
Old Dec 8, 2011 | 12:15 PM
evilempire18's Avatar
Sea Foam
I drive my Evo 8 100 miles a day,4 days a week and normally full up every 2 days. I probably get about 220 to the tank. Which I know is bad but I start a 4.00am and leave right before the traffic starts so I’m always in a rush. I tried a bottle of Sea Foam in a half a tank of gas. At a 1/4 of a tank I started feeling better throttle response. I let the gas light come on and filled up. Now I clearly get 100 miles more to the tank. Not bad for $8.00. Just thought I would share.
Old Dec 8, 2011 | 12:44 PM
High_PSI's Avatar
WOW, really, which can did this?
Old Dec 8, 2011 | 01:00 PM
FTY Motorsports's Avatar
sea foam rocks i usually run half a bottle into a vacuum line and the other half into the tank
Old Dec 8, 2011 | 01:06 PM
Ramen_Noodle's Avatar
Was considering Sea Foaming my car before my 60k mile service since the dealer is putting in fresh plugs and oil anyway.
Old Dec 8, 2011 | 01:35 PM
DJAfterShok's Avatar
I've heard some people also run it in their oil right before an oil change. Any input on that?
Old Dec 8, 2011 | 01:36 PM
djikonatx's Avatar
not bad at all . wich can is this ???
Old Dec 8, 2011 | 01:58 PM
bluebanana23's Avatar
I would say the only place that's worth treating is pouring into a vacuum line. IF you run tier 1 gas and change your oil when you're supposed to, your engine and fuel system should be relatively clean.
Old Dec 8, 2011 | 02:07 PM
boostedwrx's Avatar
Alternative is to run nothing but E85 ...?
Old Dec 8, 2011 | 02:08 PM
ROGERV's Avatar
I use it in the fuel tank about every oil change on my car, keeps the e85 gunk build up off my injectors.
Old Dec 8, 2011 | 02:27 PM
xbattousai's Avatar
To OP did you use the whole bottle in the tank?
Old Dec 8, 2011 | 02:39 PM
10isace's Avatar
I've used it (1/2 can) on a vacuum line to find a exhaust leak, then the other half in the tank. I couldn't tell a difference, but I found the leak Could be because I run E85 and my fuel system is clean already.
Old Dec 8, 2011 | 02:49 PM
Pssst's Avatar
YES!! This is what I like to hear, I'm just under 1/4 tank and will be going to get a can today after my presentation. Thank you for sharing OP (I get roughly 245 per tank btw blah)
Old Dec 8, 2011 | 03:05 PM
Ran an entire can in the vacuum line + half a can in a friends speed3 100 miles before an oil change. The exception is that this car does get a **** ton of mileage since she delivers pizzas. Had to add some more oil to thicken up the mix but it ran like a champ until she changed the oil.
Can't comment on running it in an EVO.
Old Dec 8, 2011 | 03:06 PM
EvoTeyn's Avatar
Soo all you do is buy the see foam, and pour it right into the gas tank? I might have to try this, been getting pretty bad mileage recently.
Old Dec 8, 2011 | 03:08 PM
You can buy it in liquid or aeresol. Using the aeresol is the easiest way to feed the vacuum line and liquid for the gas tank or oil.
