Sea Foam
Use the brake booster line or any line that leads directly into the intake mani.
the size of the line dosent matter, you just need to watch out how much fluid you suck up at once. To much and you can stall the car. I put 3/4 fluid into the gas tank and im going to put the rest in the brake booster tomorrow and see how my performance is.
I ran just a little under a full bottle into my gas about 2-3 days ago when I saw this thread, and seen everyone talking positive about it...I forgot that I used it lol, until I was Driving to work today
I was thinking to myself " she's runnin real smooth lately " then I remembered the Sea Foam! It defiantly did its job. If your doing fluid maintenance , might as well spend $9 and run it through your car. I'm going to use it every oil change now!!!
Just ran 1/2 the can in the gas tank andput 1/3 in the intake the other day. curious about results with people putting it in their oil? i have about 1/3 or a little less left does this actually help? if so how long should you run it in the oil before an oil change?
I've heard you need to do an oil change fairly soon after using this in the intake. Apparently it thins out the oil a bit and could lead to trouble. I have no data to back this up, but it makes sense to me. I used it in the intake and gas tank. After that tank was used up I did my oil change. I just planned it out 250 miles before my oil change.
Larger lines can actually be harder to use because it's harder to keep the car running with them disconnected since they are larger vacuum leaks. It'll work fine though, you might just have to blip the throttle cable to keep it going.
