Boost... HKS EVC 6 Install...
Old Dec 30, 2011 | 05:35 AM
Evo8*'s Avatar
Does anyone know what the STOCK boost levels are for an Evo VIII.
I've been told many different figures, ranging from 14psi up to 22psi.
My boost gauge shows 22psi tapering to 18psi.
I have recently installed a HKS EVC 6.
Should I be setting this to 22psi and hold? I have tried but my controller is having a hard time reaching over 15psi when the target boost is set to 22...
Old Dec 30, 2011 | 07:41 AM
black_beauty's Avatar
so is it showing 22psi or not getting to 15psi?
Old Dec 30, 2011 | 03:24 PM
Evo8*'s Avatar
Sorry... I re-read my original post. Before I installed the EVC, I was getting 22 tapering to 18. With the EVC installed, it struggles to get past 15psi when the target boost is set to 22. It's a long way off and something I didn't expect.
Old Dec 30, 2011 | 04:34 PM
That boost controller plug into the OEM plug? Your ECU is prob not letting it boost if so. Do you have evoscan and a tactrix cable?
Old Dec 30, 2011 | 08:13 PM
Evo8*'s Avatar
Ive left the stock boost controlling solenoid plugged in and capped off. Can I just un-plug the solenoid without any problems?
I do have evoscan but need to buy the proper cable from them. I had a OBDII cable already, but it doesn't like evoscan - just will not connect.
Old Jan 1, 2012 | 09:14 AM
anthony penn313's Avatar
Did you set your waste gate boost to 11 lbs ?
Old Jan 2, 2012 | 02:39 AM
Evo8*'s Avatar
I haven't set my waste gate to anything. Didn't even realise you could. I thought it was a spring...
Old Jan 2, 2012 | 02:40 AM
Evo8*'s Avatar
After a bit more experimenting, if I set my EVC target boost to 26psi, it will hit 22...
Old Jan 3, 2012 | 07:31 AM
It is a spring that opens up at 11 lbs of you run no controller you need to set that in the evc I did and I got my target perfect , plus have you tried to use the offset ?
Old Jan 3, 2012 | 02:41 PM
Evo8*'s Avatar
I haven't actually... I need to sit down for an hour with the manual and go through it again... I'll just do a master reset and see if I can get it right...
Old Jan 4, 2012 | 04:07 AM
Evo8*'s Avatar
Just read up on the HKS website about no reaching target boost... I didn't realise that "standard maximum boost" was WG pressure... Jeez... Why didn't they just write that in the manual!!
Old Jan 4, 2012 | 08:11 AM
Yeah man I bought my car with one in it and after hours of trying to figure it out I went to a mbc then back to the hks and did a master reset and set everything including the way the manual said including the wg boost to 11.4 and offset to 0 and I did target perfect besides a spike up one or two lbs I know I have an exhaust leak and prolly boost leak but I went though the same problem and I reset and just did the initial settings and it works great now
Old Jan 4, 2012 | 08:12 AM
Sorry on a iPhone
prEVOke
Oct 20, 2015 01:31 AM
SWOLN
Oct 15, 2015 11:07 AM
ghad
May 25, 2014 02:27 AM
Evo Tengoku
97
Mar 24, 2014 09:13 PM
quinn6051
May 12, 2010 03:51 AM
