friendly wager...
just watch for the crappy differential to blow out then you can take the win give him a few warm up passes it will break ive seen all motor s2ks break multiple times they wont hold inital torqure remeber its just a honda
what is his set up going to be besides the turbo , lower compression headgasket? good lsd? hondata tune ? what fuel ?
s366 is big big big turbo. That thing will be crazy fast if he can get traction and knows how to drive/control.
Same driver, my money goes to s2k. ( Fp Green evo vs s366 S2k)
If his car is done right your going to need a lot more then a little green. I've seen stock motor s2000's go as fast as 9.80's with a precision 6766. I would say your going to need a minimum of a black if your stock frame, and if your t3 I wouldn't go smaller than a pt6262 or a 3582.
And yes cams for you are a must. Look into the gsc s2's or the Buschur bf 272's. And obviously all supporting mods.....good luck
Sgt Blamo
234
Feb 11, 2008 06:27 PM
