EVO 6 Wont Start - Please help guys
Old Feb 20, 2012 | 05:16 AM
sau_33's Avatar
Exclamation EVO 6 Wont Start - Please help guys
A little background info on what's been happening..
My car was stolen 2 weeks ago and has been since recovered, unfortunately I only had 1 set of keys which the fu*k!rs didn't leave with the car.
I got a set made by a locksmith and now the car still won't start, I read somewhere that certain Evo's came with transponders and was wondering who could confirm whether or not this is actually the case with Evo 6's?
Just that I don't have insurance and already looking at forking out heaps of money on body damage they caused and don't want to spend $400+ Mitsubishi want for a new key and recode etc.
Any help would be great.
Old Feb 20, 2012 | 05:19 AM
SaulHudson's Avatar
Please give details on what happens when you try to start it. We have no idea what your problem is if you just tell us it doesn't start. Do your lights come on in the cluster? Do you have power to everything? Do you hear fuel pump? Does the serpentine turn? Does the starter engage? Do you smell fuel?
Old Feb 20, 2012 | 05:33 AM
sau_33's Avatar
Thanks for the reply,
Battery is hooked up to another car that's running.
All lights on dash come on as per normal.
As I turn the key to ignition I hear 2 or 3 suttle clicks from inside the engine bay area
Turn the key to start the car and it turns over
Tries to start but doesnt fire up.
Old Feb 20, 2012 | 05:36 AM
sau_33's Avatar
I get power to everything from what I can see.
cd player turns on and works fine.
Starter seems to engage as it is trying to turn.
I don't smell fuel.
Don't hear the fuel pump on engaging the ignition however I do hear it when I wind it back down and put it back into IGN from trying to start it, I hope that makes sense.
Old Feb 20, 2012 | 06:02 AM
SaulHudson's Avatar
The serpentine does turn but it just wont fire then? You try to start it multiple times and don't smell fuel? Did you try hitting the gas pedal while starting?(dumb question I know) I think your problem is fuel related. I would take the fuel rail off and see if injectors squirt when you try to start.
Old Feb 20, 2012 | 06:21 AM
sau_33's Avatar
Ok great I'll try doing that and see what happens. Any other suggestions?
Do you know if it sounds like it could be a factory immobiliser? Do you know if the Evo 6's came with them at all?
Old Feb 20, 2012 | 07:01 AM
SaulHudson's Avatar
Not really sure on this one. I don't think it has anything to do with your key though.
Old Feb 20, 2012 | 12:17 PM
GreenOctane's Avatar
check all your fuses and check for spark,
Old Feb 20, 2012 | 06:06 PM
sau_33's Avatar
what would the clicking sound be as I put the key into IGN?
Fuel pump relay not engaging?
Old Feb 20, 2012 | 08:04 PM
SaulHudson's Avatar
Clicks are usually relays kicking on. Its possible that the fuel pump relay is bad, but relays going bad is pretty rare. There is numerous thing that could be the problem here, fuses like posted above could be a big one. I suggested checking fuel at the rail because you aren't smelling fuel and if there is no fuel at the rail then clearly your problem is somewhere in the fuel circuit. Just a FYI when you check the fuel rail, make sure you do not lose any of the orings. There are 3 on each injector, they like to run away when you pull the injectors.
Old Feb 20, 2012 | 09:10 PM
barneyb's Avatar
I think it was an option.
Old Feb 20, 2012 | 09:19 PM
SaulHudson's Avatar
This may very well be. Any idea where the immobilizer would be? OP is getting nearly all of his ignition, ie cluster, starter ect.
I cant see a key fob immobilizer being fuel. I could see no ignition at all
Evo_Goodness
Aug 3, 2016 04:20 PM
xjy19860421
Jun 18, 2016 11:09 PM
fafaforza
Apr 20, 2016 04:17 PM
2theMAX
North Texas Evo Club (NTEC)
Nov 19, 2012 07:40 PM
EVOMIZ
Nov 27, 2011 05:33 PM
