clunking
Old Feb 20, 2012 | 06:33 PM
evo854880's Avatar
clunking
my car clunking in the front end, only happens while moving, sounds like suspension , but everything looks fine..
Old Feb 20, 2012 | 07:48 PM
AJCaron12's Avatar
Dude, how would we be able to tell you what's wrong with your car over the internet? Have you gotten the car in the air yet? There's a lot that can clunk in the front end. Check the sway bar links and bushings.
Old Feb 21, 2012 | 10:25 AM
HyperHoHo1's Avatar
Have one person drive the car slowly and another outside listening for the sound so you can narrow it down to a certain area of the car. That would help with pin pointing the issue.
Old Feb 21, 2012 | 10:29 AM
BDecker9's Avatar
Jack the car up, put two jackstands underneath in the front and wiggle the tires back and forth while listening and trying to see where it's coming from. There's many different things that could be causing the "clunking"
Old Feb 21, 2012 | 10:34 AM
05evoGSR's Avatar
https://www.evolutionm.net/forums/ev...end-noise.html
End thread
Old Feb 23, 2012 | 06:31 PM
decathect's Avatar
is it while turning? braking? going over bumps? off camber?
need more info, and then I can attempt to advise.
Old Feb 24, 2012 | 10:01 AM
evo854880's Avatar
No bumps. Only when turning. I can tell its not an axil it sounds totally differnt.. I would almost belive strut mount but i never herd of ond while turning.. But it sounds the same.. Dose it on smooth road
Old Feb 25, 2012 | 04:51 AM
techghost's Avatar
I have the same problem but for my this noise comes when I'm go on speedbumps.
I've coilover and hks camber plates.
I need help as well
boyvang
Oct 12, 2015 12:34 AM
SuprEVO
Jul 7, 2007 08:01 AM
ThEHiTMaN
Dec 12, 2006 10:50 AM
MuslimEvoFreak
Nov 24, 2005 08:16 AM
JT-KGY
Mar 23, 2004 10:37 AM
