code 82
Old Feb 22, 2012 | 05:10 PM
ahmed moustafa's Avatar
code 82
hey guys i got an evo 9 and i have a problem with the acd system the three lights come on and i got code 82 need help
Old Feb 23, 2012 | 05:35 AM
mcm308's Avatar
82 is ACD pump failure.. welcome to the club..
Old Feb 23, 2012 | 10:09 AM
frankmc's Avatar
82 - Pump malfunction or pressure sensor failure or acd relay failure
can you hear the pump running when you turn the key on?
Old Feb 24, 2012 | 05:32 AM
Yes frank I hear the pump but it runnig for about 45 second and stop not like before it was run about 5 second and stop and there is no pressure coming out from it about a week ago I have open the rear diff and get off the clutches so can u tell me how could I know that I install them right again if there is a vedio or something could help cuz after this the three light of the acd turning on
Old Feb 24, 2012 | 11:05 AM
frankmc's Avatar
it sounds like you have air in the system,
Have a friend get under the car (use axle stands) find the bleed screw on the transfer box, Insert your key and turn it to the on position. (dont start it) Press your gas pedal to the floor and you will hear the ACD system pump kick on and then open the bleed screw,
don't let the pump run for more than 5sec,
make sure you check and top-up the acd reservoir as it will empty quickly
1 ignition on gas pedal down bleed screw open
2 bleed screw closed ignition off
repeat 5/8 times until all air is gone
felickz
Oct 19, 2014 09:14 PM
Ridge727
Aug 12, 2014 06:01 PM
Redline-Z
May 5, 2012 01:38 AM
walshly
Oct 1, 2011 07:40 AM
xexitenglishx
Jul 13, 2011 08:44 PM
