Ureathane or metal shift base bushings?
Old Mar 25, 2012 | 07:34 PM
tmaddox's Avatar
Is it hard to change the under hood or base bushings? Any how-to's on the forums about it?
Old Mar 25, 2012 | 09:47 PM
paposse71's Avatar
https://www.evolutionm.net/forums/ev...g-install.html
Old Mar 25, 2012 | 10:05 PM
FQ-300's Avatar
Just installed the Beatrush Shifter Base Bushings (Poly). Shifts are more tight and crisp. I had previously installed Agency Power Underhood Bushings. Noticed an immediate difference after those were put in. Now it is even better after the shifter base bushings. Great combo of easy, diy mods. Total install time was less than 30 mins.
Old Mar 26, 2012 | 03:59 AM
superkizuna's Avatar
I have some speed source underhood and braided steel upper and lower clutch line. I did this right when I got a new ACT clutch and flywheel. I was loving the shifting action. Next I'm going for base bushings. I'm going to go metal.
Old Mar 26, 2012 | 06:26 AM
Stradag's Avatar
I have metal underhood bushings and metal shifter base bushings, been running them for three years and they are perfect. Theres no reason to not get them, they are cheap and make a huge difference in my opinion.
Old Mar 26, 2012 | 08:40 AM
03BoostedVIII's Avatar
Its extremely easy. Shifter bushings are attatched to arms right in front of the firewall on the driver side attatched to the back side of the tranny. Just pull out the cotter pin, slide off old bushing/washer install first half of the new bushing and slide your shifter arm back onto it. Install second half, reinsert washer/cotter pin and your good to go. Takes about 5 mins I did it in the parking lot of Earthworks park with a pair of needle nose pliars
Old Mar 27, 2012 | 12:44 PM
tmaddox's Avatar
thanks to all, sounds like one thing I can do in a parking lot and not get arrested!
Old Mar 30, 2012 | 01:06 AM
You can also pull into a busy parking lot, crank up the beats, and start break dancing with the doors open. Then get whoever's best at facebook to take snapshots....... I'm just sayin.
Youtube it and you could make =3 <----- cat face you pervs
all of that and no negative police attention + fb coverage x youtube'n it up = bi-win!
jimmcfeely
May 6, 2015 01:32 PM
getek20
Feb 27, 2012 09:02 PM
livnpaintball2
22
Mar 15, 2010 03:31 PM
Nomad4g63
19
Oct 19, 2009 09:35 PM
