Huge puddle from transfer case
Old Mar 5, 2012 | 09:21 AM
silverguy's Avatar
Welcome to the EVO world. Im on my third EVO and I grew to realize that these cars are by far the most tempermental cars ive ever owned... yet I still have one.
Sorry man.
Old Mar 5, 2012 | 12:49 PM
Arxylis's Avatar
Sorry man.
I know how you feel... but it's all worth it when it's running right. This is by far the most capible vehicle I've ever owned. Unfortunately there's a down side to all that capibility as well. Oh well, gotta pay to play right?
Good news is I get the car back Wednesday evening with the suspension, rotors, and alignment finished. Then on to the trailer again to bring it back to the firehouse to get a handle on what's going on with the transfer case.
Old Mar 5, 2012 | 01:08 PM
brenner's Avatar
youd know it was gear oil by the smell. rotten eggs.
Old Mar 5, 2012 | 01:27 PM
Arxylis's Avatar
Yeah, it did kinda smell like that. It was very thick, almost like maple syrup. It looked brand new as well, which makes sense because the fluid was changed just before I got it. I checked the drain and fill bolts and I can't find any evidence of it leaking from there. I need to get a good look up by where the exhaust runs closest to the TC.
Old Mar 7, 2012 | 07:33 PM
Arxylis's Avatar
Quick progress report...
Got the coilovers and rotors put on by the shop. Picked the car up today. Got my new TB in the mail as well. The guy at the shop said that it looked like the leak was coming from one of the half shafts on the transfer case, so I'm thinking its the seal on that side. MUCH better news than having a crack or something in it. I'm wondering if the fact that I had one side jacked up for a few days if that had something to do with it, because there was no evidence of a leak prior to this.
Old Mar 7, 2012 | 07:35 PM
Arxylis's Avatar
Here's a kinda half assed pic I got from under the trailer when it was loaded up:
Old Mar 7, 2012 | 09:44 PM
impact blue's Avatar
Same problem that I had if the fluid was reddish it was from the resevior or at one of the lines. If it was green its coming from the tcase itself. I had a problem with the seal.
Old Mar 7, 2012 | 10:07 PM
gpfury86's Avatar
Mine was leaking in the same spot when I bought it. Whoever put the new axle seal in the t case didnt press it in straight on mine. Also it's definitely not t-case fluid coming from there if thats where its coming from, should be tranny fluid since it transfers over. There's a diagram somewhere on the site that shows the part number for the seal. let me look here it is second post in the thread its 30145p like 16 bucks at dealer. https://www.evolutionm.net/forums/ev...case-leak.html Mine was leaking much less though like a dime size puddle in a night....
Old Mar 7, 2012 | 10:48 PM
barneyb's Avatar
I hope you are aware that saying there is a huge puddle under the transfer case is another way of saying the transfer case is empty.
Old Mar 9, 2012 | 05:05 AM
Arxylis's Avatar
Yeah, from the looks of it the transfer case pretty much leaked out its entire contents over the course of only a week. The fluid is greenish yellow in color, so its not trans fluid, so maybe its not from one of the side seals. I'll have to get a better look at it this weekend to get a more definitive answer...
Old Mar 11, 2012 | 06:17 PM
Arxylis's Avatar
So... I filled the TC with new fluid and went for a quick drive. Afterwards I took a look under the car and saw a constant drip of fluid, just over one drop a second, a rather significant leak to be sure. There was also fluid all down the exhaust for about two feet. I took a couple more pics to try and get a better idea of what I'm dealing with here.
I can't see too well exactly where it's coming from... Nothing around here with a lift is open on Sundays, so I'm gonna see if I can get it up on one after work tomorrow. I'm starting to believe that I've got a crack in it, I'm not sure what else could bleed a transfer case dry within a span of 10 minutes.
Old Mar 11, 2012 | 06:46 PM
Well im not crazy mechanic but my best advice would be from me to you would be to get some cleaner under there and put it on a rag and wipe it off with a rag or towell or windblast it down make sure your topped off with fluids since you lose alot and put it on the lift that way you can trace it a bit better.
Old Mar 11, 2012 | 07:37 PM
4RETECH's Avatar
Clean it off and get something like this:
http://www.castlepackspower.com/inde...acing%20Powder
Baby powder works also.
Good luck
aceventura188
Jun 9, 2015 10:58 AM
webguy330i
May 7, 2014 11:13 PM
OZ_kidd
Lancer How Tos / Installations
Jul 10, 2013 09:28 AM
def1
14
Apr 25, 2009 03:38 PM
RA42925
14
Jun 20, 2008 09:31 AM
