need to replace my acd pump. help!
Old Mar 15, 2012 | 02:16 PM
agile14a's Avatar
just want to get some feedback as to what my best options would be. i earlier posted about the 3 lights (tarmac, gravel, snow) coming on all at the same time. really tight financially at present and would like to explore all possibilities. would appreciate all suggestions/recommendations. thanks!
Old Mar 15, 2012 | 02:30 PM
Raptord's Avatar
You can either get a used one off the forums (~3-400$), have it rebuilt (600$), or buy the rebuild kit and do it yourself (215$).
Info regarding rebuilds is available here:
http://acd-tuning.com/acd-pump-rebuilding.html
Old Mar 15, 2012 | 03:38 PM
impact blue's Avatar
Your link does not work? why?
Old Mar 15, 2012 | 03:42 PM
Ahh I remember seeing yoru post awhiles back. hey listen before you start plunking yoru money everywhere my best advice to you would be to first check the resevoir and the lines for little leaks. Then bleed the system until there is no air through the checkvalve.
Bench bleed it through the bleeder cup this is a two man effort so ask someone for your help on it. Ive created a diy for this on youtube to properly help you. If the light doesnt go back to a single light then your pump is probably on its way out so do not drive the car.
Old Mar 15, 2012 | 07:32 PM
Raptord's Avatar
Works fine for me.
Good idea; try bleeding it first and see if it works afterwards. I would even say open it up and take a look at the parts to check for corrosion. Clean everything up, reassemble it, and bleed it. That got mine to work for a while when I did it (failed again after another track day though, at which point I bought a used one)
Old Mar 15, 2012 | 07:46 PM
Davedangerous's Avatar
Geez man don't scare the guy. It's completely safe to drive the car with the lights on. I've been doing it for 30K miles and I"ve read others who have done the same. I'll be rebuilding my pump in a month or so and I'll post my results. Until then OP follow impact blues directions to narrow down and be certain that the pump has failed.
Old Mar 15, 2012 | 08:10 PM
agile14a's Avatar
i brought my car to paramus mitsubishi for diagnosis. they checked everything and bled the pump but the lights still come on. they've ruled that the pump needs replacement. i don't think i can buy a new one so i'm checking my options.
will you be rebuilding yours yourself?
Old Mar 16, 2012 | 09:13 AM
I'm going to do the rebuild myself.... acd-tuning has a couple of options you can buy the parts from them or you can have them rebuild the pump for you with a 2 year warranty for 1/3 of the price of a new pump or you can buy the parts diy.
Do some more research, if you don't feel comfortable doing it yourself talk to matt at acd-t.
Old Mar 17, 2012 | 07:25 AM
agile14a's Avatar
where are you based and when do you plan on doing the rebuild? i'd like to do the rebuild myself. it would be great though if i can do it with somebody who knows exactly how to do it
Old Apr 17, 2012 | 04:08 PM
I'm in MA....just got back from vacation so I need to get caught up at work (and house/yardwork) before I take a crack at the rebuild. But first I need to order the parts. Shoot me a PM when you get started.
Old Apr 20, 2012 | 07:37 AM
yacubkep's Avatar
Veteran: Air Force
sweet thanks for the link on the rebuild!
Old Apr 30, 2012 | 07:44 PM
just rebuilt mine;
https://www.evolutionm.net/forums/ev...-acd-pump.html
Old Oct 17, 2012 | 11:44 AM
Activ8's Avatar
Dave, if the pump does fail, wouldn't it be possible that the motor would run continuously and burn up the coils (I think that's what happened to my car's ACD after the pump corroded). Would it be sensible really to run the car that long?
rbelchev
Dec 29, 2015 03:55 PM
EVOEvolved
Nov 18, 2013 12:28 PM
NocturnalEVO
24
Jul 29, 2005 06:54 AM
kapolani
Dec 24, 2004 07:56 PM
OzRally02
Oct 21, 2004 08:20 AM
