Causes of knock...Should i worry?
Old Apr 21, 2012 | 11:26 AM
dastallion951's Avatar
Well if your going to get it tuned, id recommend to replace the plugs make sure the gap is the same on all them prior to the tune. Will make it easier on your tuner, to tune around your possible phantom knock, and if it is that then make some adjustments on your knock sensor in the ecu, to keep the light from blinking. While you replace the plugs check your ignition coil boots and plug wires make sure there good. These small things will keep your car from disappointing you on dyno day, and also will help ensure ruling out most potential issues with random knock.
Old Apr 21, 2012 | 11:52 AM
kanovic's Avatar
I talked to my tuner and he told me that as well. I have new oem plugs in the garage waiting to install them before i go. Im waiting to hear from him about gap because it seems that a lot of people run .022 which is what i was going to gap them to. Thanks for the input guys
Live4Redline
Jul 17, 2024 07:09 AM
thedru13
Nov 3, 2014 08:58 AM
jjayp
Mar 12, 2011 12:01 AM
CMB
Apr 11, 2010 07:38 AM
EvoTech
Jul 8, 2005 07:13 AM
