EGR valve gone bad
Old Apr 20, 2012 | 06:18 AM
heSOshAdy's Avatar
EGR valve gone bad
Morning EvoM,
My Evo threw some codes earlier this week related to the EGR valve. I've been experiencing some idle issues, power-loss, and louder engine noise/vibration (especially when slowing down). Do these symptoms seem to confirm that the EGR valve needs to be replaced?
Also, I am planning on taking it to the shop, but could anyone inform me on how much parts/labor could be? The EGR valve itself is around $90.00, but I'd like to know a figure including the labor.
Thanks all!
Old Apr 20, 2012 | 06:22 AM
hamx0r's Avatar
I would just remove it and change the setting in the ecu... There is a How-to Thread on here.
Old Apr 20, 2012 | 08:09 AM
Thore's Avatar
STM EGR Delete. $30 shipped with oem gasket priority mail
Old Apr 20, 2012 | 09:00 AM
svt_lightning01's Avatar
^^^ solved my issue
Old Apr 20, 2012 | 09:34 AM
heSOshAdy's Avatar
Are there any negative sides to removing the EGR with the STM kit? Would it require a retune?
Thanks for the help!
Old Apr 20, 2012 | 09:59 AM
grim~'s Avatar
nope,only positives. less weight and doesn't heat up the intake manifold. and you will need to go into the ecu and turn off the periphery for the egr.
Old Apr 20, 2012 | 01:07 PM
heSOshAdy's Avatar
Is driving around with a bad egr valve not a good idea? It's my daily driver so if my engine is at stake then I'd rather not take any chances.
Also, will if I remove the EGR, will I be able to pass emissions?
Old Apr 20, 2012 | 01:21 PM
blowngasket's Avatar
EGR = Better MPG, Id get it fixed. And you can do it yourself its Very easy.
there was a whole thread about this weather it was better to have or remove it, a whiles back.
Old Apr 20, 2012 | 10:49 PM
Thore's Avatar
How do they check emissions on cars where you are at?
If they just plug into your ECU, you can have a tuner do a work around. If they actually test what comes out of your tail pipe or do a vision inspection, then you better just replace the EGR.
Old Apr 20, 2012 | 10:53 PM
02-Lancer-Es's Avatar
Its probably not bad just probably popped a small vacuum hose on the back of the intake manifold .
fostytou
359
Oct 23, 2025 09:54 AM
LakerRaider
May 17, 2017 04:20 PM
hamilton_eddie
Lancer Troubleshooting
Sep 1, 2014 12:13 PM
Nominox
Aug 1, 2014 09:39 AM
Tommytooth
Mar 1, 2013 08:45 AM
