Evo 9 Not Visible Modifications
Old Apr 25, 2012 | 10:05 AM
  #31
dastallion951's Avatar
Originally Posted by llDemonll
did you even read the OP?
he lives in hong kong; inspectors are much more strict there than cali/US
Yea and how do you know there much more strict, there are plenty of ways to get around it, Ive passed state ref inspections twice, and smogging it a couple of times. I think my advice is pretty sound to getting around it.
Old Apr 25, 2012 | 10:20 AM
  #32
Blue91lx's Avatar
Originally Posted by Evo_Jr
This is a bit overkill for 300whp, but very good different options to go with. Or possibly a very safe, conservative tune
I just wanted to give the OP all of his options in one post..........
Or he could do all of them and run like 15# and 0* of timing
Old Apr 26, 2012 | 05:29 PM
  #33
hatakashi's Avatar
wow thanks for all your replies... to conclude so far I'll look into...
1. ECU
2. Cam change
3. exhausts
Is it a MUST to replace certain stock pipes with more robust ones once the hp is increased?
Old Apr 26, 2012 | 05:40 PM
  #34
deeman101's Avatar
Whats the quality of HK gas? Whats the octane? I think that will determine what mods you need. If its comparable to the US then 300whp is easy.
ecu tune
lower intercooler pipe
maybe cams
maybe (most likely not) some porting of stock manifolds
If you have to keep stock exhaust then you'll still need to add more.
Also the only pipe worth replacing is the lower intercooler pipe. Nothing else will add power. Intercooler won't really make a power difference unless you go for 350+.
Old Apr 26, 2012 | 07:41 PM
  #35
Ginglingston11's Avatar
Originally Posted by Coppi5151
If you're only looking for 300whp...its easy on the IX.
Not sure what octane fuel you have in HK...but on 91octane and dynapack dyno my RS put down 306whp.
This is with:
Cosworth panel filter (drop in replacement for stock)
3" downpipe
3" catback (very discreet with cat in place)
Simple, hidden MBC
Tune
Done!
Agreed!!
I put down 316hp/317ft lbs on 93 oct on a dynojet. Mods were intake, downpipe, test pipe, stock cat back. Megan manifold and o2 housing. Fuel pump and MBC. Im sure the OP can make 300 easily
benIX
Feb 21, 2014 04:21 AM
Freebs
11
Nov 13, 2011 09:05 PM
InitialE
Oct 2, 2011 01:51 AM
AnotherLeveLDJS
13
Apr 14, 2009 11:22 AM
jonjon123
Nov 2, 2007 09:56 PM
