Stock Water Temp Guage Help
Old Apr 24, 2012 | 04:22 PM
datiger69's Avatar
Had a shop replace the heater core and now the stock water temp guage does not work. All of the other guages work fine. Don't want to have to take the dash apart again. Where do I start trying to find the problem? Any help would be greatly appreciated.
Thanks
Old Apr 24, 2012 | 04:46 PM
thedru13's Avatar
Check to make sure the temp sensor is hooked up also might be bad. 40 bucks to replace
Old Apr 24, 2012 | 05:01 PM
datiger69's Avatar
Thanks for the tip. Where is it located? I have a VIII.
Thanks
Old Apr 24, 2012 | 05:16 PM
thedru13's Avatar
Old Apr 24, 2012 | 05:34 PM
datiger69's Avatar
Awesome. I will take a look. Thank you very much.
Old Apr 24, 2012 | 06:23 PM
EvilTechnology's Avatar
Curious what the shop charged to do the heater core?
Old Apr 24, 2012 | 06:45 PM
datiger69's Avatar
The car ran hot so the head gasket needed to be changed. Had some fluid in the cylinder. Head did not crack. Whew
Old May 12, 2012 | 02:09 PM
datiger69's Avatar
Wanted to post an update. The problem is now fixed. The connector to the sending unit for the guage was bad. Crimped on a new connector and all is good. Thank you everyone for all your help.
sexydexy_evo4
Sep 28, 2016 08:41 AM
steven121
Oct 1, 2012 03:54 AM
yesevo
11
Oct 31, 2011 10:19 AM
IAmADirtDude
Mar 2, 2009 06:50 PM
nils
Aug 22, 2005 07:46 AM
