Evo 8 Tach wiring to cluster
My tach in my 03 Evo does not work and i want to check the wires behind the cluster and make sure that the tach wire is good. What color or pin # is the tach wire that goes into the back of the cluster? I know that pin 58 on the ecu is the tach signal (green / white) but cannot find a green/white wire that goes to the back of the cluster. Can anyone help me.
Pin 11 in plug C-01 is your tach signal. Origin is pin 58 in ECU plug C-117.
See section 54A-60 in 'Chassis electrical - Combination meter assembly and vehicle speed sensor' - inspection procedure 2 - tachometer does not work
thank you very much. I will try and see if i am getting power to that wire and try and get my damn tach working again.
i checked the wire and i am not getting any power going to it i dont believe. I tried with the car on and off. I am not sure exactly how to use my multi meter but shouldnt it have around 12 volts when the car is running?
tboboy
Aug 7, 2010 03:39 PM
sblvro
Dec 20, 2006 07:39 PM
