clutch issue... thoughts ?
Old May 19, 2012 | 09:33 PM
gomcar25's Avatar
A few weeks ago, my clutch line started leaking. I replaced it with a one piece from stm, Along with a new slave cylinder. Today my clutch got much softer then under normal conditions. Now I have a loss of power and a soft clutch..... Thoughts of problems and solutions ?
Old May 20, 2012 | 05:48 AM
bigben's Avatar
You don't have a mixture of dot3/dot4 fluid in the reservoir do you? Seems like I've read on here that dot4 messes with the seal(s) in the cmc and csc. I see you have an 03 just like me. I'd recommend putting a new cmc on just because of the age/miles.
Old May 20, 2012 | 07:05 AM
fafaforza's Avatar
And the master cylinder is fine? Did you take the rubber cover off to see if theres any leakage on the inside of the cabin?
Old May 20, 2012 | 07:56 AM
gomcar25's Avatar
I do have a mix of both :/, but I'm not leaking fluid. The clutch catches its completely out.
Old May 20, 2012 | 08:13 AM
fafaforza's Avatar
Try bleeding again. If you search, you'll see a good number of threads with people losing pressure, even after repeated bleeding. If you're not leaking anywhere, I'd try replacing the master cylinder, and if that helps, you can then buy a rebuild kit or $40 and have a spare.
Old May 20, 2012 | 08:16 AM
gomcar25's Avatar
Man that's gonna be a pain in the ***.
Old May 20, 2012 | 08:24 AM
fafaforza's Avatar
Nah, 2 bolts on the inside, and a cotter pin to release the pedal. Then take off the banjo bolt inside the engine bay. Replace and reverse order.
And while you're there, might be worth replacing all the fluid (clutch and brake) if you aren't sure what you have (DOT3 or 4, or even 5).
Old May 20, 2012 | 08:31 AM
gomcar25's Avatar
So, save me some search time. What should I run dot3,4,or5?
Old May 20, 2012 | 08:35 AM
fafaforza's Avatar
DOT4 is fine. You should never mix DOT3,4 with 5, though.
Old May 20, 2012 | 04:21 PM
gomcar25's Avatar
Drove around today, no acceleration. In fourth gear the car builds boost and goes nowhere. Then the clutch actaully engaged and I was moving.... I think its time for a new clutch.
Old May 20, 2012 | 06:05 PM
fafaforza's Avatar
So for example you're at 5,000RPM and the car isn't moving? Yah, that would point to the clutch itself.
Old May 20, 2012 | 06:08 PM
gomcar25's Avatar
Well i have a new project this week....
ohYouEvo
Aug 28, 2016 10:58 AM
BlowMeOff
Sep 28, 2012 11:55 AM
Nohatn
May 31, 2012 08:36 AM
bumblebee04
Apr 4, 2011 10:02 AM
raywong
Nov 15, 2003 11:52 AM
