So, EVO Motor Swaps?
Old May 27, 2012 | 12:34 AM
  #46
USCGSAM's Avatar
From: Detroit metro area Michigan/Washington DC metro area
Originally Posted by Blue91lx
I've decided that IF I had an:
-Extra Evo Shell
-Extra LS1/Megasquirt System
-Extra T56
-Extra Ford 9"
Then I'd totally do this just to anger everyone.
Oh, and I'd stance it.
#hellaflush
LMFAO wow that was well played sir, or maybe BAG it ...... lmfao too much
i posted the orig pic with the intent of seeing what else was out there, not for people to argue over how pointless or stupid the idea of a swap would be. the craftsmanship and skill to shoe horn a V8 of any kind into the engine bay is beyond my competency level. so, from me that alone garners some respect. the same could be said for people like top secret when they removed a 2jz and replaced it with the smaller 3sgte sacrificing power for weight and balance. but idk, seems there is just alot of hatred for thinking outside the box. in southern MD (where i live) there are more then a handful of the 280Zs and RX7s riding around with V8s. i never really thought much of it, other then the amount of time the owners spent other the hood trying to make the thing work and drive. just my .02$
Old May 27, 2012 | 05:43 AM
  #47
StarScrm's Avatar
Originally Posted by Butt Dyno
Drifting isn't a motorsport.
http://forums.nasioc.com/forums/show...31&postcount=9
It's judged, not timed.
It's sad you feel that way.
Old May 27, 2012 | 05:45 AM
  #48
StarScrm's Avatar
-Extra Evo Shell
-Extra T56
-Extra Ford 9"
#hellaflush
You and me both my friend!
Old Mar 17, 2019 | 03:15 PM
  #49
PD88's Avatar
Evo 8 engine swap idea
What would all be needed to put a 3.5 Ecoboost in a Evo 8.
Old Mar 19, 2019 | 05:49 AM
  #50
GSX_TO_EVO's Avatar
Holy thread revival, but to answer the question. It will take a lot of money, or if you have the skills to fab everything needed yourself, it will take a lot of time and money.
i can’t believe it’s 2019 and people are still wanting to do this kind of stuff.
Old Mar 19, 2019 | 10:37 AM
  #51
Pal215's Avatar
Post #4 said, "If you have the machines, extra hands, you can weld and you have a lift it wouldn't be too hard."
It's probably going to be hard, but I agree with the first part of the statement. Custom motor mounts, custom bell housing, different ECU and harness, different set of sensors, a way to convert the Mitsu speed sensor to talk "Ford", probably through the use of an aftermarket ecu in the first place or microcontroller as a signal translator. There will be a lot of annoying little bits that have to be modified. Prepare to cut and weld a lot. Check out the B is for Build Datson 240z on youtube to find out what kind of work and tools it would to take to make that engine fit in an evo.
Old Mar 25, 2019 | 12:50 PM
  #52
Tanro's Avatar
Bulk cash. Like just a duffle bag full of it. Give to a shop with a good reputation and pick your car up in 2-3 months.
Get back a car slower than dsm with a 20g and a set of cams or just a stock powerplant evo with a FP green and cams.
Old Mar 25, 2019 | 02:10 PM
  #53
TougeGod7's Avatar
IDK if someone said this already, but what about a LS4 with a different bell housing to adapt the evo 5spd trans to fit it?
Old Mar 25, 2019 | 02:13 PM
  #54
Fox_IX's Avatar
I don't think I'd want to run such a torque-y motor on a stock transmission. Even if it was built, it'd give me anxiety haha. Then again if you're spending the money on adapting an LS to an evo trans you can probably afford to build it or put a sequential in it.
Old Mar 26, 2019 | 03:52 PM
  #55
TougeGod7's Avatar
I don't see the tq being a problem for the trans. A lot of ppl make 500+ tq in their evos. Biggest difference would be the synchros not having to work as hard seeing he engine is being rev'd nearly as high.
P.S. I'm not a real mechanic so take anything I say as a grain of salt.....maybe less
Old Mar 26, 2019 | 04:47 PM
  #56
Fox_IX's Avatar
Yeah but those guys aren't making 500+tq at less than 3k RPM. It's the low RPM torque I'd worry about.
Old Mar 27, 2019 | 06:52 AM
  #57
Evo9isLife's Avatar
5 Year Member
The only swaps I would even consider being an "upgrade" would be a K20/K24/F20/F22
Extreme Tuners
40
Dec 14, 2014 11:34 PM
evodave
Evo 'For Sale' Exterior Styling
980
Jan 17, 2012 11:53 PM
DrasticK
41
Jul 11, 2010 06:45 PM
ETS Michael
20
Sep 14, 2009 08:39 AM
DrasticK
Jul 9, 2009 11:04 PM
