Idle Issue, Video Inside, TiAL leaking?
Old Aug 11, 2012 | 07:20 AM
kaonashi's Avatar
Ok so this is a better video of my idle issue this is with the car in neutral.
The bov makes a whistle if i barely blip the throttle... someone said the spring might not be right? Also I have the bov T'd & I just read it had to be straight to the Intake manifold? where should I route it on the manifold without having to T it?
boost leak shows nothing but the valve is closed while the car is off.....
Old Aug 11, 2012 | 07:34 AM
Mochafrap's Avatar
Vid isn't working for me?
Old Aug 11, 2012 | 08:56 AM
kaonashi's Avatar
Sorry forgot to make it public its viewable now.
Old Aug 11, 2012 | 10:09 AM
adriano_917's Avatar
Do you have a popcorn machine inside that evo ?
Old Aug 11, 2012 | 10:10 AM
kaonashi's Avatar
It's the sunroof, I removed the headliner to fix the motor. It's very noisy...
Old Aug 11, 2012 | 10:20 AM
Does it leak at idle with the car stationary, and is it vta or recirculated ? If its vta and your still on the maf theres your problem right there.
Old Aug 11, 2012 | 11:09 AM
kaonashi's Avatar
Does it leak at idle with the car stationary, and is it vta or recirculated ? If its vta and your still on the maf there's your problem right there.
Yes it still leaks while stationary, just tends to do it more while im rolling, @ first I thought it was the brakes squealing but they are new & it makes the noise with just a little 1500rpm blip. I can put a piece of tissue paper by it and you can see it blowing it.
VTA & yes it is on stock maf .... I know its suppose to be recirculated..... but I've had my last car tuned with the same setup, & it never leaked @ idle. Someone told me to "Shim" the spring inside to make it sealed a little better?
The car had a VTA bov when i purchased it. Owner said it was tuned but when I looked into it. Everything was stock on the ECU not even boost cut % where changed ever.
JT-KGY
772
Jan 3, 2025 07:04 PM
Kendogg
Jan 29, 2016 06:18 PM
kaonashi
Aug 7, 2012 08:07 AM
nismo05
Jul 29, 2012 10:43 AM
ZoSilverEvo
Jun 28, 2012 09:10 AM
