Power steering leak Evo 8
Old Aug 24, 2012 | 06:58 PM
re-rx7's Avatar
My power steering started leaking today. Its leaking where the bolt/nut on top of the pump secures the pressure line. Are they copper washers under there? Loos to be leaking at the very bottom of stud?
Old Aug 24, 2012 | 09:02 PM
hatesposers's Avatar
you're in luck... I just dealt with this problem 5 months ago...
it's an O-ring, but mitsu doesn't sell the O-ring on it's own. (itsnot even in the parts system)
AND any O-rings you can get at the hardware stores that are the circumference that the origional is, is too thick to be used...
So, I purchased this kit from harbor freight.
O-ring Kit Harbor Freight
And stretched some of the smaller O-rings from the kit over the pipe till it just fit in without pinching.. 4 months, and 2 cross country drive's later, and no leak.
Old Aug 24, 2012 | 10:38 PM
re-rx7's Avatar
Really? Wow. I looked at it before work and it looks like a copper washer that mounts to the bottom of the nut/stud to the top of the PS pump. Leaks pretty bad.
Edit. I can see it now it is a copper washer.
Old Aug 25, 2012 | 12:37 AM
NEVERMIND.... I was wrong... I am talking from the resevoir to the PS pump... You mentioned it clearly that it was the pressure line... you are correct, it's a crush washer.
Old Aug 25, 2012 | 03:19 AM
re-rx7's Avatar
I hope to have it taken apart today.
Old Aug 25, 2012 | 11:27 PM
re-rx7's Avatar
Holy crap you were right. It was the rubber o-ring/seal.
YAMAHArYder
Jun 7, 2016 09:48 AM
shuttersboy
May 6, 2016 10:27 AM
grubiaco
Lancer Engine Tech
Apr 16, 2013 07:33 PM
ammitsuevo
Feb 13, 2005 08:37 AM
ammitsuevo
Feb 12, 2005 02:46 PM
