A/C compressor oil capacity and wiring
Old Aug 27, 2012 | 11:42 AM
okevolutionVIII's Avatar
I'm moving back to Texas next week and will be leaving my Evo stored in my shop until I'm settled in and the weather cools down a bit due to no AC.
I'm still trying to diagnose the problem with my AC and purchased a low mileage compressor for a low price and will be installing it soon.
Just wondering if anyone knows the correct amount of oil to add to the compressor and also if the single wire that runs to the connector powers the compressor as I have no power going to that wire and have even jumped it to the battery with no luck in spinning the compressor.
Old Aug 27, 2012 | 12:24 PM
Murf's Avatar
You can get charging kits that have the proper amount needed for the weight of R134 in that kit. Not sure how many pounds an evo system takes.
Old Aug 27, 2012 | 12:33 PM
barneyb's Avatar
The oil circulates with the refrigerant. It could be sitting in the condenser, evaporator, compressor or drier. The usual advice is to drain what oil you can out of the compressor, measure and add that amount and a little extra.
And, yeah, just one wire. If you jump from the battery and nothing happens - bad clutch.
The clutch is a wear item and can be re-shimmed to maybe get it working again. There's a thread or two around about doing this.
Old Aug 27, 2012 | 12:42 PM
I know the Evo hold 18oz of R-134. I'll just throw that other compressor on, vacuum the system and start from there.
Thanks for the input.
Old Aug 27, 2012 | 01:48 PM
mt057's Avatar
Hope this helps....
M-Ray90
Lancer Troubleshooting
Jan 29, 2021 02:04 PM
Tmosser
16
Jul 27, 2016 03:00 PM
bnr34rb26dett
Aug 27, 2014 11:33 AM
S3CR3T
Jun 14, 2013 06:15 PM
sadc
Apr 16, 2013 05:55 PM
