rpm hang issue?
Old Sep 5, 2012 | 03:26 AM
white_evo27's Avatar
rpm hang issue?
while im driving if i push the clutch in over 2200rpm the rpm's will hang there as if the car has cruise control, it never drops unless i put the car in 1st and slowly let off the clutch with no gas to get it to roll, then the rpms will fall... now if im driving and i push the clutch in under 2200rpm they will drop to normal idle. anyone have any idea what could be causing that to happen? its a PITA when in traffic. iac? throttle cable issue? any help would be appreciated. thanks! btw running AEM (no maf)
Old Sep 5, 2012 | 04:03 AM
jameelrose's Avatar
A tune fixes this on the stock ecu. Not sure about aem though.
Old Sep 5, 2012 | 06:41 AM
metalsaber's Avatar
Had the same issue.
1.) Clean your throttle body with cleaner.
2.) Is it an aftermarket throttle body? If so, it just may need replaced. Basically the flap isn't closing properly due to issues with the housing or flap. I changed to a different brand and it's been fine ever since.
Old Sep 7, 2012 | 11:02 PM
Originally Posted by metalsaber
Had the same issue.
ill try and clean it, its a stock TB on a magnus v2 intake manifold
Old Sep 7, 2012 | 11:12 PM
SyZyGy1394's Avatar
What BOV/DV do you have?
Old Sep 7, 2012 | 11:19 PM
Tial
Old Sep 8, 2012 | 02:42 AM
S3CR3T's Avatar
I recently got my car tuned and it now does this mine hangs at 3k for like a second with the clutch pressed in. I assume since my rpm hang problem came from a tune that a tune could also fix it.
Old Sep 8, 2012 | 09:40 AM
SyZyGy1394's Avatar
Originally Posted by white_evo27
Tial
Maybe you have too stiff of a spring. I'm using a 9 psi spring right now and want to try out the 7 psi one. I still have a little huff from the turbo before the TiAL opens, or at least sounds like it is, so I'm gonna try a softer one and see if it alleviates it.
Old Sep 8, 2012 | 10:00 AM
ReignMan24's Avatar
i had this issue, turns out u need to adjust ur clutch pedal, surprised no one suggested that yet
Old Sep 14, 2012 | 06:20 PM
forcedkseries's Avatar
My car has a similar issue. Only mods are intake turboback and a exhaust
*clutch
Old Sep 14, 2012 | 06:30 PM
ChUt26's Avatar
Try adjusting your clutch pedal.
Old Sep 14, 2012 | 06:35 PM
I attempted that. Its a pretty aggressive clutch, I feel like I don't have much play in the pedal now
Old Sep 15, 2012 | 07:27 AM
BEKevo's Avatar
Check the TB seals as well, especially if youre going to clean it. Mine use to "hang" as well, and I alleviated the problem with new milspec TB seals.
Old Sep 15, 2012 | 09:32 AM
veebee's Avatar
yeah, check those tb seals. i ran into a similar problem, except if i would push the car hard for a short burst, it would hang around 3k and my air/fuel gauge would read lean (instead of "---" indicating the tb is closed) and sure enough i had a seal that was in absolutely horrendous shape
MikeyT
Nov 13, 2016 11:49 AM
ezzey
May 9, 2016 09:40 AM
kaak
Jan 19, 2016 11:32 AM
neonglh
Apr 16, 2015 06:18 AM
lucke24
Mar 15, 2012 10:29 AM
