Stock IX - Low Boost
Old Sep 18, 2012 | 10:12 AM
Montini06's Avatar
Did you do a boost leak test to make sure there aren't any leaks
Old Sep 18, 2012 | 10:42 AM
jrandy's Avatar
Not yet, but this is my next step.
Old Sep 18, 2012 | 10:50 AM
fastyouth1313's Avatar
how many miles on the car?
i bet your throttle body shaft seals are leaking and maybe you injector seals.
http://www.evoscan.com/technical-veh...ke-boost-leaks
Old Sep 18, 2012 | 11:10 AM
jrandy's Avatar
the car is at roughly 40,4xx miles and is stock. Originally I assumed that the car was missing the boost pills, but when I went to check, all the vacuum lines were factory with the pills installed.
I actually ran across that link yesterday when I was searching.
Thanks for the advice. Boost leak test should tell alot.
Old Sep 20, 2012 | 09:52 AM
MechTech's Avatar
Definitely do a boost leak test. Only reason I said boost gauge was it looks like your spike to drop value (~.3 bar) is the correct drop for a stock car but it is low holding boost.
twinspoolin94
Cobb AccessPORT
13
Apr 16, 2015 01:44 PM
dsmluck
Jan 2, 2014 06:08 AM
cumminsracer14
48
Oct 24, 2013 01:11 PM
Viegasjuice
Apr 16, 2013 01:50 PM
EvoPower81
Sep 14, 2010 12:57 PM
