Clunking noise in reverse
Old Sep 26, 2012 | 12:56 PM
icole's Avatar
This morning when I backed out of my driveway I noticed a clunking noise. It is repetitive, and its frequency is directly related to speed. It does not happen when I drive forward. When I got home from work I rolled down a hill backwards in neutral with the engine off. The noise still happened. I still have not heard anything unusual while moving forward, including rolling forward in neutral with the engine off. I have 45000 miles, and I have never revved it up and dropped the clutch. I have not gone to a track, and I changed the transmission and differential fluids about 10000 miles ago. It sounds pretty bad, what could this sound be?
Old Sep 26, 2012 | 01:21 PM
icole's Avatar
I called local dealer, and described the problem. They said it could be the Trans ring center which they estimated would be 300 to fix. I asked them to repeat the name of the part 4 times, and "trans ring center" was the best I could hear, but I have never heard of such a part, and transfer case would be more than $300.
Old Sep 26, 2012 | 01:34 PM
richdegrave's Avatar
You have a 6 speed correct that's the problem if it is lol
Old Sep 26, 2012 | 02:22 PM
icole's Avatar
Yes I have a 6 speed what is this part?
Old Sep 26, 2012 | 02:28 PM
icole's Avatar
I can handle $300 it is too bad that I am the second owner or it would be covered. I got the car with 4000 miles. I wanted a new 2006, but dealers were jacking up the price at the time.
Old Sep 26, 2012 | 03:14 PM
Is it hard to get into gear first and reverse
Old Sep 26, 2012 | 07:10 PM
icole's Avatar
No. It runs perfectly in forward. I have a little crunch going into second worse when cold, but this has been true ever since my first trans fluid change.
Old Sep 27, 2012 | 03:57 AM
icole's Avatar
I am still hoping to find out what a trans ring circle is and what it does. Should I go to mitsu dealer, or my local mechanic? If I keep driving will I damage something else? Could I fix it myself? Any info I can get would be greatly appreciated. I cannot seem to find anything about this part on google or in this forum.
Old Sep 27, 2012 | 08:42 AM
littlewack's Avatar
Does the noise happen while you roll backwards, or does it happen as soon as you press the brakes? Mine has a noise when pressing the brakes, Its the pads slopping around inside the caliper. Just an FYI
Old Sep 28, 2012 | 04:22 AM
icole's Avatar
It happens when I roll back. I thought about the brakes, but coasting backwards with the engine off it sounds like it is coming from front center, but a vibration in the wheel could transmit through the drive shaft.
Old Sep 28, 2012 | 04:23 AM
icole's Avatar
Also if I back up slowly and short distance it doesnt happen.
Mr.Sparkle
757
Apr 18, 2017 08:04 PM
CeliOnce
Jan 28, 2016 07:54 AM
eVoRox
17
Jul 15, 2015 03:38 PM
weiyan8
Sep 18, 2012 10:38 AM
Babaki
Aug 13, 2012 08:16 AM
