Trunk lid help
Old Oct 5, 2012 | 09:51 AM
ghui99ss's Avatar
Trunk lid help
Hi everyone, I was just wondering if a trunk lid on a 02 lancer would fit on a 06 Evo with no issues? Thanks in advance
Old Oct 5, 2012 | 09:54 AM
evo8426's Avatar
Yes but without the torsion bars from the wingless trunk when you pod the lid it will fly open.
Old Oct 5, 2012 | 10:03 AM
DSMdynamic's Avatar
I have an RS trunk lid on my GSR and it flies open all the time. Where can I get these said torsion bars to prevent that?
Old Oct 5, 2012 | 10:21 AM
evo8426's Avatar
Could try a scrap yard, you can add some small sand bags or remove the bars and it won't have the springing effect.
Old Oct 5, 2012 | 10:31 AM
markjr11bravo's Avatar
Or you could just do like me and my VIS trunk (stretch my arms out wide, use my left fingers to pull the trunk switch, and then quickly side shuffle so that my right hand stops the lid from flying up). Ha people look at me like I'm on crack every time I open it
Old Oct 5, 2012 | 10:37 AM
evo8426's Avatar
I used to do that when I went wingless or I would open the trunk with the key haha
Old Oct 5, 2012 | 10:42 AM
Yea unfortunately this VIS trunk doesn't have keyhole. I've no **** gone into my trunk by quickly pulling down the back seat a few times Lolol. I could fix but I'm pathetically lazy
Old Oct 5, 2012 | 11:02 AM
DeeezNuuuts83's Avatar
That's exactly why I didn't want to go with VIS or any of the other companies that made trunks without keyholes. Sure, they're less expensive, but then they have this issue, plus they may not always fit as nicely.
Old Oct 5, 2012 | 11:08 AM
The fit was good, but yes like you said, it only took about a week for me to start missing the keyhole ha
Old Oct 5, 2012 | 11:12 AM
Does anyone know where to get the RS trunk bars? Or how much they run? If they're cheap I can just get them... not that I might turning the key and just catching the trunk.
Old Oct 6, 2012 | 03:56 PM
CoachG's Avatar
torsion bars for non wing trunklid are parts#
MR991365
MR991366
Double check in case they've changed recently. Should be about $35 each if you buy new. Much less if used or scrapyard.
Good luck!
Old Oct 6, 2012 | 06:21 PM
zenki-s13's Avatar
Haha. That was me while I had my wing off to reclear it.
Taylor
Viegasjuice
Dec 11, 2013 10:09 AM
Peazoo
Nov 23, 2013 08:08 AM
SleepySamurai13
Jun 3, 2013 05:25 PM
