Engine starting problem
Old Oct 19, 2012 | 08:40 AM
Ev0ikon's Avatar
I doubt they have AutoZone in NewZealand.
Old Oct 19, 2012 | 05:13 PM
Blitz VII's Avatar
This haha...
So after further tests it seems as if it's something to do with the fuel settling in the pipes nothing to do with the battery. This morning I had the same problem starting, but I stopped trying to start, pumped the gas pedal twice then it started first try.
Any ideas on what's the best way to diagnos the problem? I don't think it's the fuel pump cause she's driving pefectly when she's going, just needing the fuel to be run through the lines to start her up
Old Oct 20, 2012 | 09:37 AM
jager89's Avatar
Cycle your key to accessories for a couple seconds and then back to the off position. Do this a couple times to pressurize the system and then see if she cranks over.
Old Oct 20, 2012 | 11:03 AM
elim0's Avatar
i had a similar issue a while back too. after installing engine mounts and playing with clutch it works fine now. (clutch pedal must be down to start car with JDM as im from AUS). my engine doesnt move at all either with the mounts in now.
also check out this thread,
https://www.evolutionm.net/forums/ev...d-fixed-2.html
im not sure which one yours might be, but maybe try and look into these options if your still finding you have trouble with it ~
hhenryjin
Lancer Troubleshooting
Jul 17, 2014 08:52 PM
Big5644
14
Jun 25, 2014 09:35 PM
ozrallyzombie
Feb 19, 2014 05:46 AM
ptm5070
12
Jan 9, 2014 12:19 PM
nmilsaps
23
Oct 7, 2012 09:00 AM
