What is the size of the drainplug thread
Old Oct 21, 2012 | 03:44 PM
impact blue's Avatar
What size thread pitch is the drainplug of the transfercase? Im trying to create a filler for it.
Old Mar 10, 2015 | 03:48 PM
OwensT4211's Avatar
Well ima bring this one back. Anyone know?
Old Mar 10, 2015 | 04:54 PM
llDemonll's Avatar
14mm threads with a 17mm socket i believe
that's a complete guess. but i know the 17mm part is true
Old Mar 11, 2015 | 04:15 AM
egis's Avatar
M14-1.50
Old Mar 11, 2015 | 06:35 AM
OwensT4211's Avatar
And I suppose any crush washer that fits will do the trick???
Old Mar 11, 2015 | 07:25 AM
llDemonll's Avatar
They will, I use MD050317 exclusively though. I like crush washers that actually crush as opposed to copper washers that...don't.
Old Apr 2, 2015 | 07:15 AM
kyoo's Avatar
is MD050317 the aluminum version?
Old Apr 2, 2015 | 12:11 PM
llDemonll's Avatar
i'm going to say yes. It crushes nicely I use them on all 14mm drain plugs that I have; cars and motorcycles. never had one leak on me
very easy to crush. you can feel the bolt and washer get tight, then you can feel it crush because the force to tighten is about 30% more but it's not inhibiting, it keeps turning, then you can feel it bottom out when it's done crushing. no need for "extra blips" or turns because you can feel it the whole way through
Old Apr 2, 2015 | 12:14 PM
kyoo's Avatar
gotcha. i was an all copper guy back around when I first got the evo. stepped away from the scene for a while and came back to these aluminum washers thinking wtf is this? lol. will just buy a bag of aluminum crush washers from napa, thanks
Old Apr 2, 2015 | 12:49 PM
LetsGetThisDone's Avatar
That's the fill. The drain is bigger. 15/16 or 24mm hex, and I think its 16mm thread..
Old Apr 2, 2015 | 03:27 PM
llDemonll's Avatar
WOWOWOWOOOWOOWOW i'm glad you're here. Honestly I didn't even read his post, I read the title and assumed oil pan
Old Apr 2, 2015 | 03:28 PM
llDemonll's Avatar
to expand on this, since i now re-read the post, i use copper for the transmission and rear diff still. i only use the aluminum crush washers on the oil pan drain plug
SleepySamurai13
Apr 28, 2017 05:04 AM
french
May 2, 2015 01:04 AM
goad_white03
Sep 18, 2013 12:23 PM
notenoughhp
11
Sep 3, 2011 03:31 PM
EVO8LTW
14
May 29, 2008 10:28 AM
