How to go about selling my evo with all ACD lights on?
Old Nov 22, 2012 | 05:47 PM
evo*7*'s Avatar
I'm currently looking at sell my evo, only problem is all 3 acd lights come on after 2 minutes of driving. Car is in perfect condition apart from this and has full service history etc. Unfortunately I don't get to drive the car much anymore and don't have the time nor the money to get it checked out by a mechanic as car needs to be gone soon because I'm moving abroad.
Should I mention this fault in the advert and approximately how much should I knock off the potential asking price with an issue like this? TBH, it could be something else causing the lights to come on rather than the pump itself so don't know how to price it for a sale..
Old Nov 22, 2012 | 07:36 PM
Jimmy Javelin's Avatar
Try using the car every couple days and see if it turns off.
For awhile the lights would come on, and then they stopped coming on and I've had no issues for months now
Old Nov 22, 2012 | 08:02 PM
Shortbus115's Avatar
Open up the gauge cluster and disconnect gravel and snow LEDs.... Don't do that. Honesty is the best policy, karma and all that.
If the lights are on, all you can do is see if there something small that can fix it. Check fluid level, disconnect battery for a few minutes, etc. If that doesn't do it then the pump needs rebuilt and it is what it is.
Old Nov 22, 2012 | 09:01 PM
Hendrixmx's Avatar
Try bleeding the system
Old Nov 22, 2012 | 09:04 PM
TwistedEvo8's Avatar
Try Buying the rebuild kit for the ACD pump and do it your self and do the job the right way and never have to worry about it again? Good Luck!
Old Nov 22, 2012 | 10:16 PM
one4's Avatar
Originally Posted by hendrixmx
try bleeding the system
+1
Old Nov 23, 2012 | 09:19 AM
FlatBlack's Avatar
Id bite the bullet and just get it fixed. I know you say you want it gone asap, but ive always found it much easier and quicker to sell a car with no problems versus one with issues. If everything else is perfect with the car and you have the full service history you will severely limit your ability to get top dollar for your car With that ACD issue, plus you will limit the amount of potential buyers which will increase the amount of time it will take to sell.
I've always found it difficult to sell a car with issues no matter how honest and generous you are with the pricing. Anyone willing to deal with the issue is going to want a significant discount on the price to deal with the problem.
Old Nov 23, 2012 | 09:30 AM
InoNothingMR's Avatar
My car did this when my alternator went bad.... Not sure of your mileage though.
Old Nov 23, 2012 | 04:53 PM
cs82685's Avatar
Personally, 9 out of 10 evo ix's I see for sale outside of this site (autotrader/eBay/etc) usually have all 3 acd lights on. If that's all that's wrong with the car I don't think you're going to be leaving much money on the table by not fixing it. It's a nice to have big the car still runs/drives fine without it.
Old Nov 23, 2012 | 05:16 PM
Chef-j's Avatar
Problem like that buyer will bite and pull down your asking price alot.
Old Nov 23, 2012 | 07:49 PM
one4's Avatar
i forgot to add... check your abs line, it might be cut. As wierd as it sounds it will trigger all 3 lights. Also check the fuse... a lot of the time that is what triggers the lights.
Old Nov 23, 2012 | 07:50 PM
one4's Avatar
Old Jan 29, 2014 | 10:24 PM
S.Brewer's Avatar
FCOTM Winner
I had a built evo and all 3 lights would come on and even flash. Driver side abs wire was rubbed through because of the tires. Click there. Try bleeding the pump if that's not it.
kyoo
618
Jul 27, 2022 11:38 AM
honda-guy
14
Dec 28, 2015 04:49 AM
Evo Man Hunter
Dec 11, 2015 07:16 AM
JHS VIII
Jun 12, 2012 03:23 PM
Boost3dxEvO
Aug 22, 2009 06:58 PM
