Help?! Battery Problem?
Old Dec 13, 2012 | 02:49 AM
NY Evo's Avatar
I just swapped out a new stock 03 turbo onto my 05 evo yesterday. Car was running fine with a little boost leaks here and there I was going to fix today. So like 5 minutes ago as I was going to drive to work, I go to start my car and it started making a fast machine gun like clicking noise (all the lights work). I opened up the hood and tried starting it and I noticed smoke coming from the right piece on the battery when I would try to start it. Any help would be greatly appreciated, Thanks !
Old Dec 13, 2012 | 04:55 AM
WikdEvo's Avatar
dead battery?
Old Dec 13, 2012 | 05:13 AM
NY Evo's Avatar
Originally Posted by Tom Stout
dead battery?
All the lights turn on.
Old Dec 13, 2012 | 05:24 AM
Hitmachine101's Avatar
clean the battery terminals, even if you dont see the corrosion take both terminals off and clean both cables and terminals
reinstall and test with a battery tester if you have one, autozone has one complementary they ll test for you, just get someone competent ( a lot of guys who work there are ignorant and simply dumb when it comes to cars )
that ll give you an idea as to whats up
Old Dec 13, 2012 | 05:25 AM
sounds like a poor connection, itll turn the lights on but when the current is needed to start the car, it clicks, very typical
Old Dec 13, 2012 | 05:41 AM
NY Evo's Avatar
Will clean them as soon as I have a chance. Question though. Could this be a reason for the right terminal to smoke when I would try to start the car? Thanks for your response btw man. Appreciate it.
Old Dec 13, 2012 | 06:13 AM
WikdEvo's Avatar
Yes
Old Dec 13, 2012 | 02:40 PM
np good luck, oh and if there isnt an autozone near you advance, or any retail car place like those stores will have that type of tester
Old Dec 14, 2012 | 08:20 PM
NY Evo's Avatar
Solution: Hopefully helps someone else in the future
So I finally figured out the problem after running numerous tests. Turns out the connector to my negative terminal was just really corroded even after using battery cleaner and a wire brush. Solution: I cut the wire that connects to the negative terminal and disconnected the connector. Bought a $13 terminal connector (had an extra red and yellow wire [useless] as a ground) and spliced the wires and connected the connector to the terminal and viola, problem solved. Thanks for the replies everyone!
BRalliart
Aug 22, 2015 08:01 AM
lmleet06
Jul 25, 2013 01:31 AM
sti killr
Jan 1, 2011 12:46 PM
white_evo27
Jul 30, 2010 10:00 PM
Kdash106
13
Jan 9, 2010 05:01 PM
