When putting the wing back on?
Old Dec 23, 2012 | 10:56 AM
silverevo05's Avatar
So I'm replacing my 9 wing to an 8 wing and I wanted to know what most of you are doing about the adhesive when putting the wing back on. Do you add 3m double sided tape or just leave it out?
I would think without it water might go back in between the trunk and wing and cause rust.
i was thinking of buying a roll of rubber mat and cutting it to size but cannot find a thin rubber mat anywhere (lowes home depot harbor freight michaels pepboys oreilys etc)
I also read you can buy thin closed cell weather stripping but I wanted to know what others were doing. I'm not worrying about going wingless later since i bought a wingless lancer trunk a year ago to go back and forth
Old Dec 23, 2012 | 12:10 PM
AJCaron12's Avatar
The first time I put my wing back on I used double sided 3m adhesive to install it. I have the wing off again right now, and I'm just gonna bolt it on without the adhesive. I don't think you really need it, although you make a good point about water getting in the trunk, which I will keep my eye on just in case.
Old Dec 23, 2012 | 12:21 PM
Eacs10's Avatar
I'm new to Evos soooo I was wondering y u would go to the 8 wing? Are they not the same?
Old Dec 23, 2012 | 12:30 PM
matrho2792's Avatar
The 8 wing is full carbon fiber and the middle section is filled with foam for added strength. The 9 wing has carbon fiber in the center section with no foam in the middle and ABS on the sides (not carbon fiber).
Old Dec 23, 2012 | 02:15 PM
R. Burgundy's Avatar
I put mine back on with a thin strip of 3m just on the sides of the base of the wing...
My trunk had a bit of rust in the corner under the wing when I bought it, I didn't consider the tape to be a possible cause...regardless if there's tape there or not water can still get caught in there.
Old Dec 23, 2012 | 02:45 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I removed the old gasket with goo-gone and replaced it with an OEM gasket.
Old Dec 23, 2012 | 07:57 PM
I went to mitsu and they said there is no replacement adhesive/gasket. Do you have a part number?
Old Dec 23, 2012 | 10:13 PM
Eacs10's Avatar
Nice! Thanks for the info
Old Dec 24, 2012 | 04:16 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
i went to mitsu and they said there is no replacement adhesive/gasket. Do you have a part number?
Lies!
6515a045
Old Dec 24, 2012 | 04:33 PM
What a bunch of lazy m^&%&^%^&
^ Thank you for the info
Did you sell yours? why?
Old Dec 24, 2012 | 04:36 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Eh?
Nope, from this to this to this:
Old Dec 27, 2012 | 05:15 PM
mdost03's Avatar
Can always get sheets of gasket material from an autoparts store and cut to the shape of the wing base. I did that on my old srt-4 and it worked well.
YoitsEVOSAL
Feb 20, 2013 01:56 PM
jester81783
Oct 31, 2010 02:39 PM
DSMEVOLUTION
Dec 7, 2007 05:59 PM
XK120
Oct 31, 2006 09:25 PM
