Obd ii
Old Dec 29, 2012 | 03:46 PM
OPENA(671)'s Avatar
Obd ii
Any ideas on why my OBD II won't be read?
I plug it in, and it says "err 1".
It's an Innova 3030.
Or is there certain types that only work on certain cars?
I thought all OBD II scanners work the same.
Help me out. Thanks.
Old Dec 29, 2012 | 03:47 PM
OPENA(671)'s Avatar
Oh I even took it in to a shop and they couldn't get a reading either.
They both had the same results.
Old Dec 29, 2012 | 03:54 PM
SmurfZilla's Avatar
Put your car on a trickle charger or swap the car battery for a new one. I had issues getting my ODB II scanner to work before and its because the battery was uber low.
Old Dec 29, 2012 | 04:22 PM
OPENA(671)'s Avatar
alright will give that a try.
Old Dec 29, 2012 | 06:01 PM
OPENA(671)'s Avatar
Tried it. No luck...
Any other suggestions?
Old Dec 29, 2012 | 06:31 PM
wisniaPl's Avatar
Are you sure you have stock ecu installed? no ems??
Old Dec 29, 2012 | 06:37 PM
DaveHA's Avatar
have you checked your fuses?
Old Dec 29, 2012 | 07:34 PM
OPENA(671)'s Avatar
I do have a apexi powerfc installed...
Does that change anything?
Checking the fuses now.
Old Dec 30, 2012 | 09:52 AM
1d10t's Avatar
I'm not sure if obd2 is observed by law in Guam.
Make sure the pin fitment is secure. Look for bent or corroded pins in the obd2 dlc.
Make sure both grounds work, and check for battery voltage at pin16
Old Dec 30, 2012 | 10:24 AM
hatesposers's Avatar
Its your power FC. it has no ODBII output
Old Dec 30, 2012 | 11:22 AM
todd6027's Avatar
power fc not obd ompliant
Old Dec 30, 2012 | 01:51 PM
SmurfZilla's Avatar
That small detail def. changes everything. Its the Power FC. Have you tried calling Apex i about this?
Old Dec 30, 2012 | 05:12 PM
OPENA(671)'s Avatar
I have called and emailed. No answer or reply.
Do I really need this in the car anyways?
I bought it used. And it came with the powerfc and a safc ii installed already.
Let me know. Thanks.
petetheheat1604
May 24, 2012 03:43 PM
tsitalon1
33
Mar 4, 2011 04:34 PM
MalibuJack
27
Sep 22, 2007 06:51 PM
EvoSid
Feb 3, 2006 11:10 AM
GotBoost25psi
Dec 5, 2004 04:21 PM
