Wiper malfunction but wires are dry
Old Feb 19, 2013 | 08:13 AM
youngcow's Avatar
Hey guys,
I originally posted in the electrical section but no one replied so I hope someone here has a clue.
So it rained a bit here and there in the past week and in the morning the rain freezes over. But it wasn't until I was driving home from work approx 8 hours later so the car had plenty of time to dry or what not because it hasn't rained for the rest of the day. During my commute home my wipers had a mind of it's own. The wipers are going off while the switch is in the off position and when i turn the wipers on, they slow down. If I use the sprayer it works at normal speed. At one point during my 30 min commute home they got stuck halfway across the windshield and the switch doesn't do jack. It would also go off while the car is off.
So I check the wiring by the wheel well and inside the cabin. Crazy thing it's dry, and sealed. Of course of 2 days of these symptoms, it happens to go away after doing all that work so my only guess is the wiper motor.
Anyone got suggestions but this thing comes back with a vengeance?
Thanks,
Young
Old Feb 19, 2013 | 10:03 PM
black_beauty's Avatar
Sounds exactly what use to happen on my s-10 when the wiper motor was dying. That would be your best bet, could always grab a test light/volt meter and check it.
Old Feb 20, 2013 | 05:42 AM
youngcow's Avatar
Thanks, I check it out when it goes bad again.
Old Feb 20, 2013 | 05:54 AM
gsrboi80's Avatar
Wires may look dry but my money is 100% on corrosion in the junction block connectors.
I'm sure you've seen this thread
https://www.evolutionm.net/forums/in...s-how-fix.html
Do yourself a favor and hard solder those wires
Old Feb 20, 2013 | 08:42 AM
fdme's Avatar
I don't own an evo so I'm not aware if it has one but I had the exact same issue with my old jeep. It ended up being something called the ignition wiper pulse unit or something like that. Just replaced the box and it worked, where as before the wipers wouldn't ever really shut off they would kind of stutter step and would only work in high and had a mind of their own. It has something to with wiper control when they are on any intermittent setting.
Here's a thread on it, you might find something similar on the evo but I dunno
http://www.jeepforum.com/forum/f13/i...roject-279739/
Also; in my experience a screwy ignition switch can cause all sorts of weird things with steering column controls.
Old Feb 20, 2013 | 12:38 PM
barneyb's Avatar
You had better check on this!
Old Feb 20, 2013 | 01:06 PM
ProPilot04's Avatar
If they're going on when the car is completely off, there's a grounding issue somewhere.
Old Feb 20, 2013 | 09:27 PM
chintrebor's Avatar
Check all your connectors in the kick panel, that's where your problem is! Clean the connectors if they are not fully corroded, if they are fully corroded out you might have to bypass a few wires around the connector. Do it before it makes your fuel pump quit on you
Old Feb 21, 2013 | 05:57 AM
youngcow's Avatar
This is the first thing I did...The connectors arn't corroded. The Seal is dry, We even took out the little box of wires under the fender, that's completely dry also. Only wire that is wet would be the turn signal but no corrosion.
Old Feb 21, 2013 | 06:00 AM
youngcow's Avatar
This is something I might have to look into when it happens again.
Old Feb 21, 2013 | 09:06 AM
ProPilot04's Avatar
It is possible that the short can be inside the coiling of the motor itself. I'm actually dealing with one of these said electrical gremlins on a particular type of Swedish car that isn't known at all for it's electrical issues
But after 25 odd years, what can you expect...
Anyway... you can use one of those green scrubby things, to make sure you're getting good solid clean contact with the grounds.
Post up what you find out if anything...
Old Feb 21, 2013 | 10:40 AM
bafhoops89's Avatar
Sounds like a ground issue
Old Feb 22, 2013 | 05:34 AM
youngcow's Avatar
Thanks for all the help guys! I truly hope it doesn't come back cause I had to remove the fuse to drive, and one of those 2 days it actually rained...FML right? haha, anyway if I do find the problem I will keep you guys updated.
Old Feb 22, 2013 | 09:48 AM
ProPilot04's Avatar
Fwiw... I wouldn't "stop" looking for this problem. Electrical shorts are serious fire hazards. And you'll never be able to put it out before it gets out of control.
Old Feb 22, 2013 | 11:41 AM
youngcow's Avatar
It's kinda hard to look for a short if it's not shorting out. My father who's a master tech says it's kinda pointless to look for a problem if it's not happening. We checked the fender and kick panel and nothing was wrong nor wet. We took a look at the wiper motor but it was working fine at that point so I don't have much of an option until it happens again.
Old Eagle
Dec 16, 2020 08:28 AM
AWD96
14
Jun 17, 2014 02:47 PM
bruce988jl
12
Mar 1, 2007 03:41 PM
nubby
Feb 9, 2005 03:16 PM
rsboy
Oct 14, 2004 01:22 PM
