Evo clutch slipping after break in.
Old Mar 6, 2013 | 01:50 PM
Randal's Avatar
Guest
So I replaced my clutch with the same act street clutch with heavy duty pressure plate that I had before, after breaking it in 600miles I tried a launch with two other passengers and it slipped so bad I left a trail of white smoke and my car stank like burnt clutch for days. But when I accelerate while on the street I have no problem. Was it that fact that I had an extra 400 pounds of weight that made it slip with the passengers?
Old Mar 6, 2013 | 02:11 PM
Ev0ikon's Avatar
That would be an easy test. Call up those two passengers and go for a ride!
Old Mar 6, 2013 | 02:17 PM
06RedRalli's Avatar
^and prepare to wear the clutch out more.
I'd try adjusting the clutch first. Maybe it's engaging at the wrong point.
Old Mar 6, 2013 | 02:44 PM
tony_b's Avatar
You need thinner friends.
Old Mar 6, 2013 | 03:42 PM
ProPilot04's Avatar
I don't think it SHOULD be slipping, but lets look at this logically.
1. Your car presumably is making more HP/TQ than stock correct?
2. Lets assume you've got roughly another 50 crank HP. That's roughly a 20% increase in HP over stock.
3. Consider that adding 400 lbs to a car that weighs (roughly) 3500lbs is like adding another 11% of it's total weight.
So you're increasing the power on side A of the clutch by 20%, and increasing the weight on side B of the clutch by 11%. And then we have to factor in that you probably aren't a professional racing car driver, the clutch may be out of adjustment etc. etc. etc.
You see how this could become problematic.
Don't forget that a clutch is a wear item. Better to have a burnt up clutch than a drivetrain that has detached itself from your car haha.
Robertv34
34
May 19, 2020 12:01 AM
JeyEvo
Aug 13, 2014 11:44 AM
Deepside
10
Sep 23, 2011 10:21 PM
justa4banger
34
Apr 5, 2009 09:19 PM
Assassin
10
Dec 3, 2005 05:57 PM
