Fuel cut/ Boost Cut
Old Mar 22, 2013 | 06:10 AM
Evolution8.5's Avatar
check the vacume line to your waistgate over boost generally only happens if your waist gate isnt opening also check the waist gate itself mine was doing the same thing was running 20psi then one day it just spiked over 30 had a hole in my gate
Old Mar 22, 2013 | 02:29 PM
Matmoya831's Avatar
Checked all hoses everything looks good but still got the cel checked it today n its P0234 over boost...
Old Mar 22, 2013 | 03:09 PM
egis's Avatar
coil packs
Old Mar 26, 2013 | 04:34 PM
Matmoya831's Avatar
Tried everything I can't seem to find the problem at all.
Old Mar 26, 2013 | 05:03 PM
evo8426's Avatar
Did you pull the intake off and do a boost leak test?
Old Mar 27, 2013 | 10:05 AM
Matmoya831's Avatar
I haven't did that but will a boost leak cause over boost?
Old Mar 27, 2013 | 10:10 AM
evo8426's Avatar
It will have the symptoms you mentioned in post #14
Old Mar 27, 2013 | 02:49 PM
Matmoya831's Avatar
But if I was loosing boost due to a leak wouldn't it be under boosting not over?
isnake
Apr 9, 2017 02:01 AM
v2lab
Aug 17, 2014 10:17 AM
eddy5201314
Aug 12, 2013 07:59 PM
vroomevo
17
Dec 1, 2008 12:41 PM
lemacfar
16
Jan 27, 2005 09:50 AM
