Need help my Evo is over heating.
Old Mar 24, 2013 | 10:51 PM
smsevo8's Avatar
Hello guys I need some help and I can't figure it out. I have a 2003 Evo 8 fully built engine from buschur racing. When I am driving my evo in the city and when my car is idling for a couple of minutes it over heats. When I drive it on the high way it doesn't over heat. I checked the fans and they turn on. I replaced the stock radiator and I put in an OEM radiator. I also replaced the thermostat, what else would it be?
Old Mar 24, 2013 | 11:01 PM
boostless's Avatar
Air in the system?
Old Mar 25, 2013 | 12:06 AM
civicej8's Avatar
Check to make sure both fans are working. Bleed the radiator. If not, check your overflow and see if your burning coolant.
Old Mar 25, 2013 | 11:10 AM
smsevo8's Avatar
Okay I will thanks
Old Mar 25, 2013 | 11:56 AM
Joshthree6three's Avatar
Head gasket leak? Check head stud/bolt torque.
Old Mar 25, 2013 | 11:57 AM
Svendiesel's Avatar
Definitely bleed it. Nose of the car in the air, radiator cap off, fill the radiator, and turn the car on and leave it on long enough til you don't have to add any more coolant and no more air bubbles pop up. Once the thermostat opens air will work its way out once coolant runs thru. Can squeeze the rad hoses to help burp everything.
Old Mar 25, 2013 | 12:01 PM
meckert's Avatar
what kind and how many fans do you have-- if aftermarket check to be sure they are blowing/pulling in the required direction-- ( i have had that happen.) Check the oil filler cap for white milky deposits---sign of a blown head gasket
Old Mar 25, 2013 | 01:23 PM
smsevo8's Avatar
It has a new OEM head gasket.
Old Mar 25, 2013 | 01:28 PM
smsevo8's Avatar
Its an after market fan it came with the turbo kit. It's a Buschur Racing T67 P Trim Turbo Kit (37R).
Old Mar 25, 2013 | 01:34 PM
10isace's Avatar
Are you going by gauge on the dash or are you logging it or both? What temp are you at when it overheats?
Is the coolant overflowing the overflow bottle?
Old Mar 25, 2013 | 02:07 PM
sourtowel's Avatar
did you use an oem thermostat?
Old Mar 25, 2013 | 06:47 PM
smsevo8's Avatar
I am reading it from the dash, I've never checked the temperature but that will be a good idea.
Old Mar 25, 2013 | 06:48 PM
smsevo8's Avatar
Yes I am using an OEM thermostat.
Old Mar 25, 2013 | 09:24 PM
reboundicon's Avatar
If you have the OEM fan, swap that in. The OEM fan cools much better than any of the aftermarket slim fans. This could be the issue if your slim fan isn't producing enough air. Try and turn the A/C on and watch the car at idle, if the fan is struggling to keep up, that could be the issue.
Keep us posted.
Old Mar 29, 2013 | 02:54 PM
smsevo8's Avatar
i checked it today and i noticed that both fans turn on at some point but sometimes one of them turn off. I have an aem engine management is there another way that i can just leave both fans tuned on at all times?
