Running with th p0304 code?
Old Apr 9, 2013 | 04:40 PM
souleater's Avatar
Hi im looking to buy an evo i have found one that is like i want . The only bug it has the guys told me it have the p0304 code but the car is running great . He told me that he have change the injector and the coil but the code come back once and a while. Would you stay far from that car or new plugs and a tune could fix it? Thanks
Old Apr 9, 2013 | 05:30 PM
egis's Avatar
you see that code means cylinder #4 misfire.new plugs,coil and plug wire should fix it.
Old Apr 9, 2013 | 05:35 PM
souleater's Avatar
Yes i know that it means misfire cyl 4 so nothing too dangerous if the guys have been running with cel for about a year he said mitsu check it a year ago and they said there was nothing wrong??
Old Apr 10, 2013 | 08:45 AM
barneyb's Avatar
I'd check compression. This is an emissions test. EPA doesn't want you driving around with gas being dumped into the cylinder if the spark plug isn't firing. How, if the injector went bad you could have a burnt out cylinder.
Old Apr 10, 2013 | 08:08 PM
AJCaron12's Avatar
Should fix it? Really? What if he buys the car and the problem is more serious than that? Valves, piston rings, etc? Do you always throw darts at cars or do you sometimes take the time to diagnose them properly?
Old Apr 10, 2013 | 08:48 PM
llDemonll's Avatar
dont buy a car that's throwing CEL's, simple as that
Old Apr 11, 2013 | 06:59 AM
egis's Avatar
it's always a risk buying the evo.what if trany or tcase on it's last leg but no cel?
Old Apr 11, 2013 | 07:42 AM
Evo dc5's Avatar
I agree, it may be something as simple as ignition but could be valves also which can be costly. No way of really knowing unless you run a compression test or leak down.
Old Apr 11, 2013 | 06:05 PM
cwyteboi's Avatar
Avoid the advice from those who would tell you to load the parts gun and pull the trigger or you'll be buying batteries, starters, injectors, coil/coil packs and end up using them as paper weights. If the guy can't have it fixed then leave it for some other poor sucker.
NightHawk
Sep 18, 2016 08:35 PM
mikes3kgt
Aug 23, 2014 04:33 PM
LanEvoDreamer
18
May 14, 2014 09:46 AM
sofly1990
16
Oct 21, 2013 08:16 AM
5LEEPERISAH23I
Sep 6, 2011 05:28 PM
