E85
Old Apr 14, 2013 | 11:48 AM
Evoaddicts's Avatar
Question E85
I had just posted about meth kits. I found a E85 station about 40 minutes away. Started looking into 55 gallon plastic drums. My question is does anyone recommend a certain pump?
Old Apr 15, 2013 | 04:24 PM
ProPilot04's Avatar
You mean a fuel pump, or transfer pumps for the drums?
Old Apr 15, 2013 | 04:30 PM
milruner's Avatar
Well first what size injectors do you have in the EVO?
MIKE
Old Apr 15, 2013 | 04:36 PM
Evoaddicts's Avatar
No im good with injectors in fuel pump. Im looking for a fuel transfer pump to attach to the 55 gallon drum.
Old Apr 15, 2013 | 04:41 PM
ProPilot04's Avatar
Honestly don't have a ton of experience with that, but I would think to just snag one of those hand crank ones? You don't really need efficiency, you just need it to work.
Old Apr 15, 2013 | 04:46 PM
Svendiesel's Avatar
I just use a grainger siphon pump, it has a long tube and its clear and orangy/reddish color with a long flexy hose to transfer the fuel out. Works great.
The first one I had I left in the drum but over time the plastic seal for the collector tube to the pump body dissolved lol so pumping was a PITA. I now remove the pump after Im finished every time and reseal it.
Old Apr 15, 2013 | 04:57 PM
ProPilot04's Avatar
FYI, OP... you probably would've gotten more hits with a more appropriate thread title.
Old Apr 15, 2013 | 05:06 PM
Evoaddicts's Avatar
what should have been the thread title
Old Apr 15, 2013 | 05:11 PM
Joshs EVO's Avatar
I just bought my first 5 gallon drum of E98 in Jan and went to the Harbor Freight store (yes they have stores as well) and I bought this hand pump.
http://www.harborfreight.com/barrel-pump-45743.html
Works great and fills a 5 gallon barrel which is then used to put fuel in the car in less than 2 mins. once you crank the pump a few times it starts sucking the fuel automatically without you having to pump anymore. It's cheap enough that you can buy a new one when this one eventually corrodes as it will sooner or later.
Old Apr 15, 2013 | 05:16 PM
Evoaddicts's Avatar
looks good enough to me thanks
Old Apr 15, 2013 | 07:35 PM
ProPilot04's Avatar
Haha... something more descriptive than 'E85'
Maybe... 'Need help with an E85 transfer pump'... I don't know. Make me want to click it!
Old Apr 15, 2013 | 10:17 PM
DaRw1n's Avatar
Make sure your drums are "air tight".
E85 will soak up any moisture it can. If it sits out without being air tight it will ruin the fuel after a while.
Old Apr 16, 2013 | 01:34 AM
bryonyndd's Avatar
Old Apr 16, 2013 | 05:01 PM
Evoaddicts's Avatar
Haha good one i put in instead of and woohhoo ��
Cadenas_evo
Driving Techniques
May 21, 2015 01:47 PM
biofee
West Region
Jul 27, 2012 08:12 AM
TurboIX
E85 / Ethanol
61
May 26, 2010 04:37 PM
evo+supra
May 4, 2009 10:53 PM
rahku
Jun 25, 2008 08:42 PM
